What is the fastest LS1 thirdgen?
Old Nov 9, 2005 | 07:20 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
just wondering what the fastest ls1 swapped thirdgen is? and i mean true time slips, not imaginary
Old Nov 9, 2005 | 03:52 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Do you mean, who is? Or what combo was used?
I dont think that many people with the LS1 swaps are running them hard on the track, so I have no clue what kinda numbers people are getting.
But, with any hope, mine will be in the top when it gets done
Old Nov 9, 2005 | 07:28 PM
my point is i want to find out what it is. im going to be a 10.50-10.80 this weekend at least and im gonna start working on the 414 soon so i want to find out what the fastest ls1 thirdgen is and what times it runs so i have something to shoot for.
Old Nov 9, 2005 | 07:33 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Friend of mine.
LS1 from a 00 TA. Converter only it ran 12.6 at 108 with slicks.
With 75 shot dropped to 11.74 at 112'
later
Jeremy
Old Nov 9, 2005 | 07:38 PM
cool, i also know hawks has some fast ones, anyone have any idea how fast?
Old Nov 10, 2005 | 02:38 AM
89FormulaLS2's Avatar
Car: 89 Firebird Formula
Engine: Custom Forged 402ci LS2 w/STS Turbo
Transmission: T56 6-speed
Axle/Gears: Moser 9" with 4.11
No, but I'll bet mine will be right up there.
Old Nov 10, 2005 | 07:43 AM
cool, well when you get some slips post them. im gonna post my sar slips for this weekends ls1tech shootout in san antonio
Old Nov 10, 2005 | 08:37 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i know im far from the fastest, but mine did a 7.9 in the 1/8th with a 1.7 60'...
that was with the stock manifolds, stock motor, thru a stock 99z28 muffler/tips...
basicly its like a 4thgen with massive weight reduction.. lol.
with some traction, gearing, and minor mods, im sure 7.6s are possible without even going into the motor.
Old Nov 10, 2005 | 08:49 AM
pskel350's Avatar
i think the speartech group went 10's last year IIRC.
the fastest n/a ls1 thirdgen would be a toss up, with a built trans so i could actually launch mine, it would be low 11's.
Leaving the line at 1200rpm with old worn out BFG drag radials the car 60' was 1.70x, then broke the trans on the 1-2 shift.
if no one will by my car soon, mine will have a turbo this winter
Old Nov 12, 2005 | 05:36 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i cant find many carbureted ones.
i havent seen many carbed ones going fast.
stock longblock 6.0, cam only.
7.23 at 95.55 all motor.
Old Nov 12, 2005 | 09:24 PM
i was out at san antonio raceway today and went a 10.94 with a 6.9 1/8th and i let off at the thousand foot. i think my run could have easily been a 10.60-10.80 because my second pass i ran 10 more mph
Old Nov 16, 2005 | 10:52 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
No times out of mine yet but I'm hoping for 11.50's or better N/A with a T56... spray and maybe go 10's, hell I don't know...
Old Nov 22, 2005 | 10:35 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
any carbureted swaps out there?
ive finally got the stock manifolds off the car and the hawks headers are on.
hope to be loweing my et real soon.
Old Nov 23, 2005 | 09:21 PM
StevenK's Avatar
Car: 91 Z28
How you like the headers? We have a very heated discussion on ls1tech going on about em right now.
Old Nov 23, 2005 | 11:46 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
the headers didnt fit at all.
i have a th350 and a spohn tq arm and run into numerous problems.
they are on and finished now, but it wasnt a bolt on and go deal.
to someone not so inclined, or didnt have a good selection of tools may be in trouble.
i dont see them being a problem fitting on a 6spd car, but an automatic you may run into trouble.
the spohn tq arm x member was a hurdle to run the exhaust under. i had to cut and chop it up pretty good.
all is well.
the car actuallly is more quiet at WOT with the headers.
cruising is about the same, but i think the idle is more deep, not loud at all tho.
im TJ on ls1tech. i think i responded to the thread where you and the gentlemen were whispering.
Old Nov 24, 2005 | 03:00 AM
StevenK's Avatar
Car: 91 Z28
Ahh, glad to see you are here as well, much more mature croud here.
I was wondering about the Spohn X-Member, I've got one for my T-56 with the nice adj Trq Arm.
I dont know if I want to cut it up.....
I would like to run the exhaust on the sides and dump right before the rear tire.....but I think thats illegal here, and would kill any hopes of ground clearance.
Old Nov 24, 2005 | 11:50 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i pretty much cut all of the bottom of the 90 degree angle off that the tubes are welded to, and the bottom of the welds on all the tubes.
prolly saved an inch all together, if it wasnt cut, the y pipe would hang so low it isnt funny.
its tucked up nice.
ill have pics loaded up tomorrow.
Old Nov 25, 2005 | 02:04 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
my headers fit great, but yes the y-pipe was bit of a pain to get to fit. I had to cut a little on my spohn x-member, then shorten the y-pipe a little cause it was rubbing a little on the tq. arm. But it all tucked nice in there now and i rarely scrape.
Justin
Old Nov 26, 2005 | 09:55 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Mr. Dude and I are neck and neck. I need some gears and some giggle gas.
Old Nov 27, 2005 | 11:22 AM
i got some headers from street performance that really worked well and were a great alternative to hawks
Old Nov 27, 2005 | 04:22 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I've been beating the crap out of mine since its been on the road, I've had some problems with the A4, but other than that everything is good. Probably 5K miles and 50 passes at the track in about a year and a half. Thats what I built it for. It will get 28 mpg on the highway also, cant beat that IMHO.
Anyone else using their car this much? lol
Old Nov 27, 2005 | 10:47 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
any pics are part #'s.
be nice to have an alternative, as some dont really cant afford (or simply) dont want to spend that much on headers.
Old Nov 28, 2005 | 07:35 AM
I got them for right under 400$ with gaskets and collectors and bolts, but they were midlength and not a full longtube
Old Nov 28, 2005 | 07:27 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
are they stainless as well?
got a bud wanting a set, but he doesnt want to spend the 784.00 it cost shipped for the headers.
i cant blame him.
Old Nov 28, 2005 | 07:48 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i rolled over 9k before i went on vacation.... currently my odo reads 9,001.... i reset it when i did the LS1 swap...
isnt that friggin cool though? i have NEVER done a swap that let my car run 7s, and run it EVERYDAY, as my daily driver, and not have a single problem...
i mean, the closest thing to a problem that ive had, is my exhaust is kinda low. ive had to tweak it a little... other then that, the only work done to it was stuff i wanted to do...
Old Nov 28, 2005 | 11:53 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
got mine running in july and just ticked off 14k yesterday. Car is awsome pulls like a beast. Since july drivin it from cali to Michigan, to boston, back to MI, and just drove it from MI back to boston today (yes i know too much driving).....but the car has been great havn't had a problem yet (even driving it from cali to MI only after having it running for 4 days!!!), beeen getting between 29-31 mpg on the freeway. Planning for a 9 inch and tires this winter then finaly taking it to the track this spring/summer can't wait.
Justin
Old Nov 30, 2005 | 10:04 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Amen...
There is so much more I can do to this thing to make it faster too. The motor is untouched and the anemic 2.73 10 bolt is still back there. I might just leave the 89 alone and start on a 6.0L/big turbo drag only car. Who knows. So many ideas, too little time.
Old Dec 1, 2005 | 08:43 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Amen...
lol, im half a step ahead of ya there.. im too stupid to leave a fun, 100% reliable car alone...
the intercooler came in this morning... now i just need a wastegate and some 60something pound injectors....
Old Dec 9, 2005 | 10:05 AM
Burn's Avatar
Car: 90 Iroc
Engine: 383LS1
Axle/Gears: 4.10
Why build a turbo kit when this is on the way?
BDS LS1 supercharger
Old Dec 9, 2005 | 02:41 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
You'd have a hard time fitting that under the hood lol. Cool anyways.
Old Dec 9, 2005 | 03:00 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
because that doesnt move enough air.
Old Dec 9, 2005 | 03:19 PM
Burn's Avatar
Car: 90 Iroc
Engine: 383LS1
Axle/Gears: 4.10
Oh come on! That thing will move enough air to blow the welds on your intake manifold. lol Oh wait that was nitrous my bad.
Another company is making one that has the TB on the rear and it might clear the hood but the firewall might be a problem.
Old Dec 9, 2005 | 03:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol, im just joking.. that moves plenty of air..
but it doesnt fit underhood.
i dont like attention.. not the kind that a blower like that would attract anyway... i just want to go faster.
i figure a turbo on a cammed LS1 will hold me over until i can get a nice low compression, forged 6.2+ Liter gen IV shortblock..... then i'll just get a bigger turbo.
(notice i said i want to go faster... it doesnt matter how fast it goes, i want to go fastER.....)
Old Dec 9, 2005 | 03:57 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
big and flashy. i like the sleek look.
turbo>aluminum drum.
Old Dec 10, 2005 | 01:42 AM
I'm doing it just backwards of that. Got the low compression 6.6L LS2, next I'll be adding on the turbo.
Old Feb 17, 2006 | 04:12 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
any current times?
Old Feb 17, 2006 | 04:40 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Originally posted by b's90cam
any current times?
i went 7.24 @ 96.96mph 1/8 mile after the headers.
previous best was 7.23 @ 95.55.
didnt pick up any ET wise, but the weather wasnt as good that day either.
im gonna run her again sunday with a few changes,.
it was pretty lean after i put on the headers.
im gonna fatten it up a bit and be ready.
Old Feb 18, 2006 | 09:07 PM
87Ls1Camaro's Avatar
Car: 87Z28
Engine: 98 Ls1
Transmission: 4l60
Axle/Gears: 307
92 ls1 truck vs lightning
I got a video here of my brothers truck at the track after we got the 98ls1/4l60 into his truck, stock then with just zo6 rims tires. Not sure what all was done to the lightning but he was suppose to be fast. Not to bad for his first night at the track running, got a 13.5 outa the truck.
http://home.comcast.net/~hough113/video.html
Old Feb 18, 2006 | 09:16 PM
Car: 87Z28
Engine: 98 Ls1
Transmission: 4l60
Axle/Gears: 307
Check out..
Check out
http://www.speartech.com/
And go to project cars and look at his 91 z28 ls1 , he was in the 11s im sure hes got it faster, and look at the mods not to much that cars my hero .
Old Mar 2, 2006 | 09:02 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
I'll be running mine next weekend if the weather holds out... should have track times soon... maybe dyno #'s soon as well!
Old Mar 22, 2006 | 12:31 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Speartech's supercharged went 10.8. Thats the fastest swap time I have seen.
Hopefully I will hit the 11's at least this year.
Old Mar 22, 2006 | 02:18 AM
  #42
Car: 1991 Camaro
well i'm installing my cam next month (232/234 .600/.600 112+2), hope to have times and dyno soon after that.
Justin
Old Mar 22, 2006 | 09:54 PM
  #43
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Mine ended up going 11.58@118.6 a few weekends ago. All motor with a t56 and a 9" Its got more in it yet... that was its first time to the track. Also, on that pass it went 7.4 @ 94 in the 1/8th
Old Mar 22, 2006 | 11:54 PM
  #44
Car: 1991 Camaro
Good work, now your movin
Old Mar 23, 2006 | 08:10 PM
  #45
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thanks man... its got more in it... gotta work out some bugs right now though
Old Aug 3, 2006 | 03:30 PM
  #46
MrDude_1's Avatar
Car: 91 Camaro Vert
9+ months later........
.... odo now reads 22,000+ miles... still no problems... fuggin awesome.
Old Aug 3, 2006 | 03:45 PM
  #47
Car: 1991 Camaro
sounds awsome, i just hit 15k few weeks ago. Planning on getting the car to the track next week, we'll see what she can run on some nitto's.
Justin
Oh ye haivng a car you ran rev to 7000 and sill drive everyday is a blast
Old Aug 3, 2006 | 04:23 PM
  #48
Stevo's Avatar
Car: Pair of 92 Z28s
i want one.
Old Aug 3, 2006 | 10:00 PM
  #49
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
My new setup is ready to drop in the car... hoping to go 10.50's or so on motor... still with a T56 and a 9".
Old Aug 3, 2006 | 10:09 PM
  #50
Car: 1991 Camaro
sweet man what you got planned, a 9 inch and some spray is my plan for next summer.
Justin
