cam swap almost finished up
Old Nov 19, 2005 | 01:48 PM
TexasLT1's Avatar
Car: '92 RS
Hopefully I'll get to drive it tonight. I'm just finishing up what started out as a cam swap.
New parts:
Combination Motorsports TN-236XL, 236/242, .555/.576, 112
Comp 987 Valve springs, 10* locks/retainers
Cloyes Double Roller timing set
CSR Electric waterpump
Speed Pro PowerForged Pistons
-4.030", flattop, approx. 11:1 CR
MadZ28 tune
I'm hoping for 12.2's with the setup now, will find out next weekend.
Old Nov 19, 2005 | 02:24 PM
Firebat's Avatar
rock on.
Old Nov 20, 2005 | 08:31 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
sounds good
Old Nov 22, 2005 | 03:34 PM
TexasLT1's Avatar
Car: '92 RS
SHE LIVES!!!!!!
haha, been running her while its still up on jackstands all afternoon, setting the rockers, fixing exhaust leaks, etc.
Haven't had a chance to drive it yet, but damn is this a rowdy cam Won't idle smoothly below about 850, even at 950 its a little jumpy. Hopefully it drives smoothly. We'll see. I'll post some vid/sound clips tomorrow
Old Nov 23, 2005 | 10:12 PM
TexasLT1's Avatar
Car: '92 RS
so much for that
Got some serious driveability issues I can't sort out. At idle I'm getting 75 kPa on the MAP, IAC is maxed out at 160, and I have to use the throttle body set screw to keep it from idling at 600. I get a MAP High code and it won't go closed loop. Apparently both O2's somehow went bad at the same time
Guess I'll pull the timing cover back off tomorrow and double check I've got everything lined up right and that the opti is/was on correctly.
Any ideas?
Old Nov 26, 2005 | 11:09 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by TexasLT1.Guess I'll pull the timing cover back off tomorrow and double check I've got everything lined up right and that the opti is/was on correctly.
Any updates?
Old Nov 26, 2005 | 12:15 PM
TexasLT1's Avatar
Car: '92 RS
yup. Opti *appeared* to be on correctly, timing chain was dead on. I played around with the Opti some as I was putting it back on, testing to see if there was anyway to put it back on with it in the incorrect position and I don't see anyway possible besides one of the other slots.
Before I run it again I'm going to pull the spark plugs and see if I find any obvious indications of a cylinder being down.
Will update again when I know more.
*Also, I replaced the intake gaskets first thinking that might be the problem but there was no change.
**One thing I'm considering now is if something is blocking the IAC port or if the IAC is stripped out or something. The computer is trying to give it more air to idle *I think*, hence why its going out to 160. But I would think it would come back down if I cracked the throttle blades, which it doesn't.
Old Nov 27, 2005 | 07:00 PM
TexasLT1's Avatar
Car: '92 RS
FOUND THE PROBLEM! I think.
So I think now it was a combination of the BBK throttle body not having an IAC bypass passage and the MAF being bad. I drilled the bypass and disconnected the MAF, everything seems pretty good. I still need to replace the right O2, but overall I think I've nailed it. Going to call around tomorrow and see how much I can get a MAF for.
Orr89RocZ
Apr 25, 2016 08:28 AM
Cameeeero
Sep 18, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
