SpearTech?
Old Dec 14, 2005 | 02:33 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
SpearTech?
Hey i been trying to get in contact with them but i get nothing. Is there some number or something that some one can point me into the right direction? I am about ready to do the LS1 Conversion or do you think i should just spend the time and do all the wiring myself. Thanks guys
Old Dec 14, 2005 | 11:03 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
(765) 378-4908 thats the number i always used and got a hold of him everytime.
Justin
Old Dec 15, 2005 | 02:00 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
With the help of a guy in my car club, we were able to do the wiring without spending the money on a custom harness. There is plenty of documentation on here and LS1 Tech.
Old Dec 15, 2005 | 10:51 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I was talking to MR. Dude and he gave me alot of info on the wiring harness. It doesnt seem that hard at all just some time and alot of reading. I rather do that then spend more money on somthing that i can do. Do you think i will have enough harness to put the computer in the factory location? I heard something about extending it or somthing like that. thanks alot guys
Old Dec 15, 2005 | 01:53 PM
StevenK's Avatar
Car: 91 Z28
No, without modification to the whole harness, it will not fit in the stock location. The 4th gen has it on the passenger side of the firewall in the engine bay.
You should take the money you would have spent on a harness and keep it in the bank account, because you will soon find out that even the simple small missing parts costs tons of money. I've probably spent more on missing bolts, belts, hoses, fuel pressure regulator, etc then I did for the block.
Old Dec 15, 2005 | 02:32 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Well F-BodY motor sport carries that AC kit i was talking about check it out.
Old Dec 15, 2005 | 02:34 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
another
Old Dec 15, 2005 | 02:38 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I dont know what im talking about sorry about that, but will this AC Kit work with the LS1 setup?
So i wont be able to have the computer in the stock location huh? I might not have alot of room to play with when the AC system is in there. Do you guys have any pics of your engine bays?
Old Dec 15, 2005 | 02:51 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
it fits under the dash if you make a hole under the airbox for the harness to fit thru.
it doesnt fit if you're trying to maintain the stock 3rdgen harness routing.
Old Dec 15, 2005 | 04:56 PM
Car: 1991 Camaro
yea if you have the time i say do it yourself, i just didnt have the time to do it. As for fitting it under the dash I say just do what mr. dude did. I did the same thing, i honestly didnt think it would work but he was right, but it BARELY fits. Just drill a 2 inch hole just under the heater box, and just above the frame. The hole is just big enough to fit and the length of the harness is just long enough to make it where the stock comp was. It wont bolt up in there like the old one did, but i just took out the brace that was holding it in and just stuffed it up in there.
I think this way looks a hole lot cleaner, if you have any more questions feel free to pm me. I think i also have a pic of where i drilled if if your still lost.
Justin
Old Dec 15, 2005 | 11:12 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
That makes me feel a whole lot better. thanks guys. Also too if you had to rate on how hard it was to do the harness what would it be 1 meaning very easy and 10 meaning very hard.
-No one has really answerd my question (except Mr. Dude) about the A/C kit that F-body motor sport offers. Just kinda loss on the Wiring part. Thanks guys a bunch.
Old Dec 15, 2005 | 11:36 PM
Car: 1991 Camaro
yes that ac braket is made for the LS1, you will have to use that if your going to use your stock k-member and not notch it. Your only other options are running a tubular k-member, or notching your stock unit.
If you are going to order that ac braket i would call them first and make sure they have it in stock becuase they are known to take your money and take forever to send your product becuase either
A. its discontinued
B. Its back ordered
If you have any other questions feel free to ask.
Justin
Old Dec 16, 2005 | 08:12 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
A. its discontinued
B. Its back ordered
Justin
yea, like he just said, they dont have the greatest rep.
ask if its in stock first and when it will ship. if they put the date out, wait to order... if it should ship right away, then pay with a CREDIT CARD... just for a little added safety.
Old Dec 16, 2005 | 10:50 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
thanks for the great tip on the AC bracket. Ill make sure its in stock. no one has really gave me a answer on how hard it is to do the wiring. sorry if im bugging but i just want to know before i get myself into trouble. You guys have been a big help with this project im about to do. Thanks
Old Dec 16, 2005 | 10:56 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
how hard depends on your skill level and how well you understand what you're doing.
if you know NOTHING about how electricity works, you've never soldered or used heatshrink... if you need someone to hold your hand to connect wires because you cant look a diagram and figure out what they do, then its damn near impossible.
if you have a basic understanding of electricity, and you can connect wires, and you do all your research and think it thru, its not too difficult.
if you know what you're doing, then its really easy.
so my answer on the 1 to 10 scale would be 1,5 and 10.
Old Dec 17, 2005 | 01:42 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Thanks Mr. Dude. Well since you put it that way then for sure i could do it. I mean i went to school for that so then what the heck. Lets put my money to work!! I just need to get a diagram of my camaro. Do you know where i could get one MR. Dude or Thirdgen LS1?
Old Dec 17, 2005 | 02:21 AM
Car: 1991 Camaro
i would PM mr. dude he has all the information on doing the wiring harness. It doesnt look that hard (after seeing what i got back from speartech, you could defintaly do it yourself but just takes time), but i know he's got some diagrams that he can send you that will make the job a lot easier.
Good Luck with the swap.....the end result is a lot of fun .
Old Dec 17, 2005 | 06:05 PM
StevenK's Avatar
Car: 91 Z28
Yeah, MrDude gave me just about everything I needed when we did the wiring on my car.
I am interested in the picture of the hole you cut for the ECM to go inside. Right now mine is sitting next to the coolent take because I can't find a good place for it where the wires will let it route....but I'll look into what you guys were saying
Old Dec 19, 2005 | 07:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
all of the thirdgen wiring i have can be found in the PDF files here:
http://66.83.134.202/travis/91FbodyWiring/
StevenK:
ive been meaning to take that pic for almost a year now.. lol. when i finally get out to the garage, i just never remember to do it.
Old Dec 19, 2005 | 10:29 PM
StevenK's Avatar
Car: 91 Z28
Originally posted by MrDude_1
StevenK:
excuses excuses
Ikes 91Z
Dec 9, 2015 03:49 PM
firechicken76
May 20, 2012 02:54 AM
Z28FAST1
Southern California Area
Oct 8, 2010 09:31 PM
Kandied91z
Jul 13, 2005 12:18 AM
Rage13
Aftermarket Vendor Review
Feb 2, 2004 11:22 AM
