ls1 swap question
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
ls1 swap question
So i have read a bunch up on this and i think i am pretty squared away. My friend wrecked his 00 z (ls1/4l60e) and is now selling me the car. I am going to swap the dash with the engine. If i do this i will pretty much be plug and play besides the reverse lights, fuel pump, and a few other misc parts right? I know i will need a new k-member and a-arms (don't want to just go mounts) and the trans x-member. I was thinking that if i swapped the rear i would be able to use the torque arm on the original drive train. Is this right or will my original torque bolt in? I can't see this being as difficult as i orignially thought it was especially since i have the whole car. By the way i have a walbro 255 pump. I was wondering though if swapping the gas tank swap is recommended.
Thanks for any help or leads to a thread i might have missed.
Brandon
Brandon
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: ls1 swap question
yes, reusing as much as possible from the donor car will make the wiring simpler, but at the cost of the extra work to make the 4thgen parts fit.. and you're limited at moving things around, diffrent then stock.
an example would be the PCM. on a 4thgen, its in a corner cubbyhole underhood.
3rdgens have no neat place to put them in the same area.
my personal belief on the best way to go about doing this is a mix between the "keep everything stock and swapped over" thought, and the "do everything custom to fit"... theres alot of decisions you'll ahve to make one way or the other, but thats why everyones swaps are always diffrent.
if you do swap, keep in mind the width diff of the 4thgen rear..
on the plus side, the 4thgen rear probly has a posi...
just alot of details.
however, the 99+ 4thgen tank does have a nicer baffle system with that bucket thing... they're the only stock tank EFI drag cars i know that can launch hard on less then 1/8th tank...
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Thats alot of questions.
You will need to notch your stock k-member or go with the aftermarket one. You will also need the new trans x-member, which you should just get one with the adj torque arm. I'm happy with mine from Spohn.
You can swap the gas tank if you want, but its not needed.
Car: 98 z28
Engine: ls1
Transmission: t56
I forgot i'm not running a/c. I may hold off on the tank for a while. My first priority would be to get it running so i would probably just buy the mounts now that i think about it. I am going to get a custom exhaust with the o2 sensors so i'm not worried about that.
If i were to keep my stock rear i could reuse my stock torque arm?
How much wiring besides the dash and engine, basically the plug and play, would need to be wired?
For some reason this just seams too easy.
Car: 91 Camaro Vert
you can use your stock one with your rear.
you can use your stock one with the 4thgen rear.
you can use the 4thgen one with your rear.
you can use the 4thgen one with the 4thgen rear.
they're interchangable.
you need to be more specific...
you're going to have to figure out each wire thats not connected to anything, and see if you need it... ooor, do it the other way, and only hook up what you need.
oh yeah and i would have to get the vats taken out i realize
there are alot of little things you'll need to take care off.. mostly DTCs and VATS.
Car: 98 z28
Engine: ls1
Transmission: t56
trhanks for the info. I haven't torn into the swap yet, it will probably be a week or two before anything happens so it's hard to ask what wire does what when i don't have. I just hope i don't cut into it and get overwhelmed. I know how to solder and I know i can drop the engine in. I was thinking that i might put the ecu where the little hole over by the passenger firewall is and build a little enclosure to keep it dry. hmm... I think this it for now. The only thing holding me up now is the dash swap. I need more info on that one and that's it.
Car: 91 Camaro Vert
however, it wont reach all the way over there.
if you look at the pics of peoples swaps, you'll see how almost all of them have it in the same general area... thats as far as it reaches.
this pic i attached shows about how far over it can reach.... you pretty much cant go any farther over.
i personally prefer to make a hole in the firewall, and mount the PCM under the dash behind it. the red arrow points to where the hole must be made.. its below the airbox, directly above the "frame rail"
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
the fuel pump and wiring fits you just need to enlarge the hole.. i used the 4th gen pump and tank as well.. just integrated into the 3rd gen lines
its quite a bitch to install the dash and do all the conversion.. power hatch.. power antenna.. defrost.. locks and windows.. door pins.. wipers.. i choose to go this way cause I thought it would be "easier".. fawk was I wrong.. im still pissing around with a couple parts... and it doesnt look as clean as the stock stuff did
heres the interior, hope to finish it one day
my computer i mounted just to the left of the engine.. i will find a way to get it into the cab just to clean up under the hood.. just need to punch a hole and extend a couple wires
Car: 91 Camaro Vert
so you mounted it under the heater box. Will this work with a non a-c heaterbox?
Car: 91 Camaro Vert
i'm just swaping the dash and console. All the other stuff seems a bit over the top.
Car: 1992 Jade Green---Trans Am Converti
It would honestly be easier to swap the entire harness then to try and use part of the 4th gen body harness.
I would get the engine in and running with your 3rd gen dash. Then later on adapt the newer dash to the 3rd gen dash wiring.
Kevin D.
Kevin D.
Car: 98 z28
Engine: ls1
Transmission: t56
why?
If i have the entire car why would i not want to use the factory harness? The car will be out of comission for a few weeks so i will have plenty of time to swap the interior and engine and not have to splice more than a couple wires. Sure there is a lot going into the dash swap, but i would rather deal with that than a bunch of wires that i have no clue where to route them.
Car: 91 Camaro Vert
why?
why?
well, it can be done in a few weeks, if you dont have to goto work or school... lol.
i would have a backup car before i started... just in case it takes abit longer.
Car: 98 z28
Engine: ls1
Transmission: t56
yeah i do. I have a handful of friends and a garage empty for almost a month and a half. i think i will be alright as long as the finances don't run short.
I guess it all depends on your standards.. Sure you could do it in a month or even two weeks, but it's not going to be pretty..
How's that three point rule go again? Out of quick, cheap, and nice; pick two and it won't be the third. I chose cheap and nice, going on 12 months it definitely isn't quick... Sounds like you're going for quick and cheap, which probably isn't going to be nice...
Kevin D.
Kevin D.
A couple of wires?? Hah.. That's good. I used the entire body harness, guess what needed to be spliced on mine:
all of the lights
HVAC
windshield washer stalk
trunk release
speakers
window motors
door locks
mirrors
Hope you have a service manual for both vehicles for the fun little differences between the way the two wiring systems work even though the colors might be the same..
Kevin D.
Car: 91 Z28
LS1 swaps take lots of time, money, and patience. If you don't have those things, then I recommend you just go get a 4th gen.
BTW shroom, what manuals did you get for the 4th gen? I bought the haynes and I *HATE* it. It doesnt have crap, no vacuum diagrams, no heater hose information, practically nothing....such a waste of money
Helms all the way.. The 92 Firebird one is pretty easy to get through as it's one volume. The 2000 F-body is three volumes and whatever you need to know is always not where you would think it should be.
Right now all 99-01 GM service manuals in stock are on sale for half price at helminc.com
Kevin D.
Kevin D.
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Originally posted by MrDude_1
no. i mounted it under the dash. the wiring goes thru a hole under the heaterbox, the PCM is under the dash. theres really no neat place to put it underhood, within reach of the stock wiring.
Car: '91 GTA
Engine: 402ci LS2
Also, as for all the negative feedback from guys saying you can't do the swap quick... they're kinda right. It took me quite awhile to do mine but that was b/c I had to figure alot of things out my self or do them different ways to suit my picky needs. If I were to do another LS1/3rd gen swap I could do it in a few weekends no problem. If you have the motor mounts, xmember, wiring, exhaust, and hoses sorted out you won't have any issues. Its really a simple swap once you know all the tricks. Search my name on here and you'll find alot of useful topics/posts... if nothing else just PM me with a question once you're in the middle of it.
Car: 98 z28
Engine: ls1
Transmission: t56
all of the lights
HVAC
trunk release
speakers
window motors
door locks
mirrors
Kevin D.
all of the lights
HVAC
trunk release
speakers
window motors
door locks
mirrors
Kevin D.
Car: 91 Z28
Jeremy, how did you mount the ECM?
I am going to use that same spot, and I was just going to take a peice of sheet metal and make something, but it looks like you somehow just mounted it to the coolent tank.
Car: '91 GTA
Engine: 402ci LS2
Let me know if you need more help, it really wasn't too hard at all, just be creative. Joined: Feb 2003
Car: 91 Z28
Good Info
Thats kind of what I had in my head, just hadnt realized someone else already did it. Hmmm, just started thinking....you know those L shaped brakets at Home depot design for shelving, 1/2 inch wide, pretty thick, maybe 2 inch on one side of the L and 2-6 inch on the other....think that would work?
Car: '91 GTA
Engine: 402ci LS2
Good Info
Good Info
Car: 91 Camaro Vert
Originally posted by GTA91
[B]Yes there is... put your PCM here just like I did. Works/looks great... all I ever get is compliments like "wow, that swap looks factory"
Car: '91 GTA
Engine: 402ci LS2
it looks ok there, but i bet my spark plugs are easier to change.
Car: 91 Camaro Vert
Plugs aren't a problem either
but theres one thing you 100% cant do with the PCM there...
...and thats put the turbo setup where im putting mine.
Car: '91 GTA
Engine: 402ci LS2
i didnt say problem, i said easier....
Already looked into it a little bit
Car: 91 Z28
Those might work but if it's what I'm thinking of it will look like crap. Let me see if I can pull my PCM out and take some pics... it turned out so clean and so factory looking.
And Dude, even if he does have to pull the ECM to change a plug or something, it slides right out of the plastic holder, so I don't see a big deal there....
***, all this talk makes me want to finish my car
Car: '91 GTA
Engine: 402ci LS2
How so, the brackets are way down at the bottom, you cant even see em unless you look between the tank and the ECM, right? Not doubting, just asking
I did that so I could keep the PCM as far away from the motor as possible for heat reasons. I know 1/2" might not make any difference in heat but it couldn't hurt and I also wanted to keep the PCM towards the tank as much as possible to give me room on the engine side of it to route hoses and other stuff. Do whatever works for you but after looking forever for a place to mount the PCM in the engine bay AND using a A/C box.... this was the only solution. I haven't found anyone else that's done it.... Senior Member
Kevin D.
Car: 91 Z28
I tried to use that location shroom, but I couldnt get it down far enough.
And Jeremy, that explains your last comment. If I do end up mounting it like you, I'll paint them so they just blend in with the plastic....or something, I'll let you know what I end up doing.
Car: '91 GTA
Engine: 402ci LS2
Shroom, I tried mine there as well but it just wasn't going to work out there. What is holding yours down? Is it just sitting there free to rattle/move around??
It's wedged nicely in the crook, and the fender bar holds it in place. You'd move the car if you tried to move it.
Of course, like I said, the HVAC relays, resistors, plugs, etc are all inside thanks to the 4th gen harness. Might not fit with just one of those things.
Kevin D.
Kevin D.
