LT1 swap, cant use stock headers?
Old Mar 25, 2006 | 05:24 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
I am swapping a 95 LT1 from a 9C1 caprice cop car and i have heard that i cannot use the stock headers on the engine, is this true and if so which headers are all u others with the LT1 using? any help is greatly appreciated, thanks
Old Mar 25, 2006 | 08:50 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I'm running Hedman 68479 painted headers and their y-pipe. They are made specifically for the angle plug heads, have d-ports but do not have any provisions for the O2 sensors. You will have to buy bungs and have them welded in.
Old Mar 28, 2006 | 07:33 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
Yes, you can run stock Caprice exhaust manifolds. You'll need a custom Y pipe though.
Old Mar 31, 2006 | 06:57 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I'm running slp 1 3/4" headers that I opened up to match my ported heads. I think that these probably fit better then most if you are willing to do a little work to make them match perfectly.
Jmo
Kory
Old Mar 31, 2006 | 09:13 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
I am running the same headers as Klortho but mine are ceramic coated. I had a custom Y-pipe made and put the O2 sensors in the Y-pipe. The only problem I had with the headers is that the back tube on the passenger side just barely touched the plastic heater box and melted it just a little. It wasn't enough to mess anything up. It was just enough to smell it melting the first day or so.
Old Apr 1, 2006 | 04:03 PM
duncz's Avatar
Car: 88 Iroc
I'm using slp headers too. I also got the slp y pipe, it made my install a bit easier.
Old Apr 1, 2006 | 04:31 PM
Klortho's Avatar
Car: 1987 GTA
Really? That's wierd mine fits with no problems and didn't come close to anything.
Old Apr 2, 2006 | 11:09 PM
dbrunner2's Avatar
Car: '89 Camaro RS
Engine: 1994 F-car LT1
Transmission: T5 World Class
Axle/Gears: Jag XJ6 IRS, 3.42, Auburn Pro posi
I'm running FlowTech 11116 headers (the ones set up for angle plug heads). Not a lot of fun to install, but that was mostly because of the weird EGR fitting I welded on, combined with having the engine mounts backwards.
As far as I know, anything that'll fit on a 1st gen small block (i.e. 305 or 350's used in our cars) with angle plug heads will also fit on the LT1.
Old May 6, 2010 | 02:17 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: LT1 swap, cant use stock headers?
I have the 68470s on my engine right now...no D ports and not sure about the angle plug business.
Old May 21, 2010 | 08:36 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I'd like to see a picture of them installed with a y-pipe. I had the manifolds on and I seem to remember one of the sides was pretty close to the k-member.
Old May 21, 2010 | 10:07 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
My headers & Y-pipe will fit as long as you don't need AIR tubes.
Old May 23, 2010 | 09:34 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Very nice. How much do they cost?
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
