LT1 Swap Motor Mounts?
Old Apr 23, 2006 | 09:56 PM
jjohnston's Avatar
Car: 91 Camaro RS
Do the motor mounts need to be replaced when swaping the 305 TBI for the LT1?
Old Apr 23, 2006 | 10:55 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
Yes, you will need a set of Tuned Port injection motor mounts. They are the only ones that will work.
Old Apr 24, 2006 | 12:14 AM
Firebat's Avatar
why only TPI motor mounts?
Old Apr 24, 2006 | 06:47 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I'm using a stock V8 mounts and the clamshells from a 78 Chevy truck on mine, no problems at all. Part numbers for the frame mounts are the same 92-92 any V8 car.
Old Apr 25, 2006 | 02:06 PM
beedo's Avatar
Car: 1986 IROC CAMARO
Axle/Gears: 3.73 posi
Any small block mounts(clamshell) will work as long as they are not LT1 or LS1. If it came with a TBI or TPI you can use either, They are all the same.
Old Apr 25, 2006 | 06:41 PM
dbrunner2's Avatar
Car: '89 Camaro RS
Engine: 1994 F-car LT1
Transmission: T5 World Class
Axle/Gears: Jag XJ6 IRS, 3.42, Auburn Pro posi
That matches my experience. AFAIK the mounting locations of all first and second generation small blocks are identical, so they can be mounted with your existing mounts. It'd be nice to swap in some polyurethane mounts, but that does require getting access to the nuts inside the K-member, and I was only able to do that by dropping the A-arms.
Old Apr 26, 2006 | 03:38 PM
TexasLT1's Avatar
Car: '92 RS
wrong, I used my TBI mounts.
You will need to use your 3rd gen clamshell and modify the passenger side mount if you are using F-Body A/C. use the forward mount position on the driver's side of the block.
Old Apr 26, 2006 | 10:11 PM
Sorry, I was wrong. I was under the impression that everyone used TPI mounts cause thats what I read to use.
I didn't have any clamshells cause I forgot to get them off of my motor before I traded it for my exhaust and I didn't get to try them.
My mistake.
Old Apr 27, 2006 | 11:41 AM
TexasLT1's Avatar
Car: '92 RS
its all good, happens to the rest of us as well
midge54
Jan 29, 2017 07:00 PM
Wesly_66
Aug 26, 2015 09:55 PM
sreZ28
Aug 14, 2015 07:48 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
