lt1 issues again help please
Old May 1, 2006 | 10:55 AM
ssean92's Avatar
Car: sold
well guys this is what i got, i have a miss that i cant find. i have changes the opti again, coil, plug wires, plugs. cked the o2's with my scanner and the rt bank is jumping around from 100-900 mv, the lft bank moves between 800-900mv. i swaped the o2's around and it didnt swap sides. so i know that there is an issue some were can anyone give me any advice? would the iac valve cause this? thats is the only sensor that hasnt been changes through out the swap. and i cked all the plugs and they are all the same. any idea's
Old May 1, 2006 | 11:33 AM
ssean92's Avatar
Car: sold
ttt
Old May 1, 2006 | 01:21 PM
ssean92's Avatar
Car: sold
well i think i fixed it
Old May 1, 2006 | 09:44 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
What was it? Sometimes I feel like I have 1 cylinder missfiring when I am sitting at a stoplight. It only does it in gear. It is idling at 550 when it does it. It has new plugs, wires, wire protectors, and it isn't throwing a code for the miss.
Old May 2, 2006 | 09:20 AM
TexasLT1's Avatar
Car: '92 RS
have you ever had it tuned? it may be "loading up" and getting split BLM's a idle, makes one bank run very rich while the other runs very lean, acts like a miss.
Old May 2, 2006 | 11:01 AM
I haven't had it tuned yet but it is running rich because of the headers. It needs to be leaned out a little bit but Im waiting for the guy to finish setting my rearend up so I can swap it and then tune it.
Old May 2, 2006 | 01:55 PM
ssean92's Avatar
Car: sold
i think it ended up being the fuel pressure. i had it at 50 and droped it to 44 and it seemed to fixed it.
Old May 13, 2006 | 12:05 PM
ssean92's Avatar
Car: sold
well the fuel pump seems to be the issue. what would cause the fuse to get so hot that is melts the fuse, dont blow it melts it. i changed the relay and still, could it be the pump?????? or is there anything else that would cause that, and also the tranny took a crap again so its out to get relooked at by my tranny guy
Old May 13, 2006 | 04:42 PM
ssean92's Avatar
Car: sold
ttt
Old May 13, 2006 | 09:31 PM
net_coma's Avatar
If the fuse got that hot I would suspect a bad fuse. Put in a new fuse and see what the new one does. The heat is current through the fuse.
Old May 14, 2006 | 09:15 AM
ssean92's Avatar
Car: sold
that is after 6 of them, samething
midge54
Dec 27, 2019 04:14 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
