when is the stock airbox a restriction
Old May 7, 2006 | 10:22 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I have the dual snorkel airbox on my car. I have removed the splash shields and cut the bottom of the boxes out. I have also opened up and smoothed out the entry where it meets the maf. I also have duct work down behind the fog lights to get cold air.
This setup worked fine with my old hotcam set up and the car trapped a best of 114mph. I upgraded to an LE2 last summer. Now the car is moving alot more air. I havent dynoed it yet, but If I can get all my ducks in a row it should make 400 plus rwhp. Is it time for some kind of custom cold air set up?
Thanks for your thoughts.
Kory
btw long tubes and a new exhaust are also in my immediate future.
Old May 8, 2006 | 12:22 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
this was done to the camaro split intake on vincentz28's car. He's putting 373 hp to the ground and I was at the dyno when he tested this and saw a 9 hp gain.
https://www.thirdgen.org/forums/tpi/...ir-intake.html
Old May 8, 2006 | 07:51 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I would say that the stock airbox no matter how much is cut out at the bottom would be restrictive on the Camaro's. You're taking a whole bunch of air, shoving it into a little flat space (which will heat the air up a bit) and trying to ram it down 58mm TB. I say put a CAI on it.
Old May 8, 2006 | 03:02 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
I really like what INTIMIDATOR Z did to his car for a cold air intake.
https://www.thirdgen.org/forums/fabr...ir-intake.html
Old May 8, 2006 | 03:32 PM
Car: 88 Iroc
Transmission: t 56
Thanks for the replys.
What I have now isn't much different than the first post. I agree that I need more though. Thanks for confirming my thoughts.
Hey Tyler
Are you driving that beast yet?
Kory
Old May 8, 2006 | 04:01 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
get ram air works great.
Old May 8, 2006 | 04:54 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Looks like his hood hits the intake pipes??? Cant belive it fits under there
Old May 8, 2006 | 07:43 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Originally Posted by Kory-88Iroc 350 tpi
Hey Tyler
Kory
I was a little, but now its all torn down waiting for the 4L60E and my 4th gen guages/dash swap. I am trying to have it ready for ThirdGen fest in 3 weeks.
Old May 8, 2006 | 08:30 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
He cut a section out of the underhood bracing
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
lakeffect2
Aug 23, 2015 08:44 AM
sreZ28
Aug 14, 2015 07:48 PM
