LS1Engine mount Bolts??
Old May 29, 2006 | 01:16 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
What did you guys use for the engine mount bolts? I cant use my 305 bolts cause there just short I dont have the LS1 engine mount bolts, so i have to ask, what did you guys use and where could i get it at? Not what holds the mount into place the engine to the mounts?
Also too, how did you guys get the Engine mounts Bolts thight with no room due to that the A-arm is in the way? thanks guys. going to try to put the motor in tomorrow
Old May 29, 2006 | 12:50 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
You will need to get ahold of the LS1 motor mount bolts thats what i used. I misplaced one of the nuts on and just ran to the hardware store and got another, so there may be a chance you can pick up some bolts at the store. also i didnt really have any issues with reaching the bolts. remove the exhaust manifolds, and you should be good
Old May 29, 2006 | 04:55 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Do you think i could get the engine mount bolts from the dealer
Old May 29, 2006 | 09:25 PM
trans_am_31's Avatar
Car: 85 Trans Am,79 Trans Am,02 Trans Am
Engine: 5.7 V-8 346 LS1
Transmission: Automatic
I also used the LS1 bolts. The dealer should have them. Good luck !!!
Old May 29, 2006 | 10:58 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Awesome!! Ill go try the dealer cause i need more things. Thanks guys
Old May 31, 2006 | 10:10 PM
Camaro0605's Avatar
Car: 1991 RS
the dealer will be able to get them for you. I've gotten a bunch of bolts that i needed from them. They are expensive, but atleast i know i'm using the correct stuff.
Old May 31, 2006 | 11:21 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
funny you say that, i went to the dealer and they told me that they didnt carry them cause there an off the shelf item at any hardware place B.S!!! Lets just say a hole day with no luck!!! I finally found the bolts, special order. Same with header bolts. Stealership SUCK!!!
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Elliswon
Aug 10, 2015 12:33 PM
