LT1 Swap. front end lighter now. need to drop?
Old Jun 7, 2006 | 10:56 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Since i have dropped in the FBody LT1.. the front end is now lighter.. and the car is sitting too high in the front.. Wondering if anyone has tried drop springs and maybe has a particular drop that returns the car to stockish height... I can't go any lower then stock because our roads here suck.. My other alternative is to pull the springs and cut em.. but dont want to get into that if i can help it. Can also use torch and heat spring up to drop it.. but afraid i wont get em even.. lol.. anyone with some insight here?
Old Jun 7, 2006 | 11:35 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Drive it, it will eventually settle back down. Mine sits just like it should with the LT1 in it.
Old Jun 7, 2006 | 01:21 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
drove it for a yr and a half.. lol not settling back down.. pretty high in the front.. and it kinda floats.. i would suspect shocks.. but should be sitting low if it were them.
Old Jun 8, 2006 | 08:06 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
As far as I know the LT1 weighs pretty much the same correct?? The LS1 brings the front up about an inch...
Question...did you by any chance take the control arms off for some reason?? If you did, did you wait to tighten the bolts until the car was on the ground? I did that in my Jeep once... Tightened everything to spec with the axle hanging. Made for almost 1" of extra height until I loosened it back up and did it right. Just an idea to throw out there!
Justin
Old Jun 14, 2006 | 08:46 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
nope.. didn't take em off
but this is the LT1 with the Alum heads.. so it will be lighter... it may just be that my struts are toast.. how does one tell anyway?
Old Jun 18, 2006 | 12:26 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I personally cannot see how a strut would effect ride height at all since the spring is what supports the weight. If for some reason that it did I couldn't see it ever being higher than stock. jmo...
My lt1 has been in my car for almost 4 years it sits at stock ride height with the origional springs.
Hope this helps.
Kory
Old Jun 22, 2006 | 02:58 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
My T/A has always sat slightly higher in the front after my LT1 swap.. I run bilstein and the eiback pro-kit..
It is about a 1/4 inch high.. I was going to cut a quarter coil or switch over to sportlines which appear to have a slightly higher ride height in the rear, given the inequality it should equal out.
As for front end float, that is the struts telling you to change them
Old Jun 22, 2006 | 07:41 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
struts are on the list. haha.
trying to gear up the AC on the fbody accessories right now.
Old Apr 25, 2008 | 09:06 PM
ssean92's Avatar
Car: sold
Re: LT1 Swap. front end lighter now. need to drop?
I know this is a old post but I am getting ready to put the factory springs in and I cut my old ones due to the ride height before, I do not have any of the ac stuff so my guestion is will they settle even with out it...
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
