couple more ?s to finish up swap
Old Jun 28, 2006 | 02:35 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
How did you guys wire your fans? im running my 3rd gen radiator and fan. Is there any way to wire it into the LS1 system so that the ECU controls it like it would normally?
Radiator questions-
Also how did you run your heater hoses?
What did you do with the TB coolant hose?
What did you do about the hole coming off the radiator right under the radiator cap(not the evap nozzle the one under it)?
Thanks,
Ill post up some pictures of the swap and exhaust and everything to help people finish theres up
Old Jun 28, 2006 | 06:17 PM
ChrisH821's Avatar
Car: 88 sport coupe
OK heres a little schematic for your fan curcuit using the existing relay and its how I wired mine. As you can see all the ECU does is gound the relay, just like the a/c control switch does. where it shows a 20A fuse a 10A should be fine since thats what the '02 uses.
As for the other stuff, I'll have to go look and take some pics. Hope this little bit helps
Old Jul 3, 2006 | 07:16 PM
dingle's Avatar
Car: '83 Camaro
Radiator questions-
Thanks,
We used a stock 02 fusebox and wired our electric fans to that.
Kinda hard to see but it's where the battery used to be on the passenger side.
Cleotiz
Jan 6, 2018 08:56 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
jharrison5
Aug 19, 2015 05:53 PM
