LT1 starter
Old May 16, 2006 | 09:28 AM
droppedbagged72's Avatar
LT1 starter
Will a starter off of a 1989 350 TPI work on a LT1? Thanks.
Old May 16, 2006 | 02:32 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Yes it will, but an LT1 starter is smaller and lighter.
Old May 16, 2006 | 02:47 PM
Firebat's Avatar
Isn't there a mini-starter or something thats smaller, more powerful, and cheaper than the LT1 starter?
Old May 22, 2006 | 09:38 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
The LT1 Corvette starter is smaller, lighter, more powerful, and cheaper than the standard F and B body LT1 starter.
Old May 22, 2006 | 09:41 PM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
From Where? GM or local parts store and what year?
Old May 23, 2006 | 10:05 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The LT1 starter is a ministarter.
Old May 23, 2006 | 09:36 PM
Coach Hawk's Avatar
and the Corvette's smaller yet IIRC, it's also a gear reduction starter
Old May 24, 2006 | 11:21 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
You should also be able to use a Hitachi ministarter with out any problems. More torque and cheaper than stock.
Old May 26, 2006 | 10:58 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
can you put this starter on a 3.1 v6?
Old Jun 27, 2006 | 08:59 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Ok so, say I go out to pick up the Vette' Starter what year do I tell them ? Im using a 95 LT1
Last edited by cheese_kake; Jun 27, 2006 at 09:01 PM. Reason: Automerged Doublepost
Old Jun 27, 2006 | 09:02 PM
Firebat's Avatar
I would think anything 92-96. But I would say 95 vette with an LT1.
Old Jun 27, 2006 | 09:05 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Ok thanks, Im going to pick that up in a little bit, but were fixing to start her up tommorrow in the new home, will the 92' starter work, its only three months old ?
Old Jun 27, 2006 | 09:07 PM
Firebat's Avatar
I dont know if a starter would work from a 92 camaro, but should from a 92 vette.
Old Jun 27, 2006 | 09:09 PM
ssean92's Avatar
Car: sold
i am using the 92 camaro starter on my car and works great. no problems
Old Jun 27, 2006 | 09:10 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Thanks man, just what I needed to hear.
Old Jun 28, 2006 | 01:53 PM
ssean92's Avatar
Car: sold
andd actually the 305 starter is a gear reduction starter also.
Old Jun 28, 2006 | 02:24 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
What does that mean exactly ?
Old Jun 28, 2006 | 02:51 PM
ssean92's Avatar
Car: sold
sorry thought you said it was a 305 starte. but a 350 starter will work also
Old Jun 30, 2006 | 07:10 PM
Coach Hawk's Avatar
For your information:
GM part number: 10455709 Starter--gear reduction, lightweight, new no core, from 92-96 LT1 Corvette
Old Jun 30, 2006 | 08:58 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
gear reduction, what does that mean ?
Old Jun 30, 2006 | 09:10 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
So you're saying that if I need a starter for my run-o-the-mill 350 sbc I should ask for a 95 Vette starter? It will be cheaper and lighter?
Old Jul 2, 2006 | 06:51 PM
Coach Hawk's Avatar
Run o the mill SBC, No. Those are still dirt cheap everywhere. If you need a replacment for an LT1 starter, then the Vette is cheaper.
Gear reduction means that in the starter, the electric motor spins fast, but the starter drive gear is reduced in speed. The advantage of this is you get the same, or more torque from the starter with a smaller electric motor, giving you a smaller and lighter starter VS a standard one.
Old Jul 2, 2006 | 07:51 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Ahh I see, are the standard F-body LT1 starters gear reduction ?
Old Jul 3, 2006 | 08:45 PM
Coach Hawk's Avatar
No, only the corvettes(Y bodies) got the gear reduction, all others, the F, B, and D bodys, have the standard non-gear reduction LT1 starter.
Old Jul 3, 2006 | 09:29 PM
Klortho's Avatar
Car: 1987 GTA
I beg to differ Hawk, the starter on my LT1 is a gear reduction mini-starter.
Old Jul 4, 2006 | 01:06 PM
Coach Hawk's Avatar
Then you've already got the Vette starter on your car.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
