Vented Optispark for 1994 LT1?
Old Jun 28, 2006 | 10:51 PM
dbrunner2's Avatar
Car: '89 Camaro RS
Engine: 1994 F-car LT1
Transmission: T5 World Class
Axle/Gears: Jag XJ6 IRS, 3.42, Auburn Pro posi
I'm toying with the idea of putting a vented Opti on my '94 LT1, even though it came with a new non-vented unit, since I really want to not have to worry about it dying on me. It's glitched on me a few times, possibly because of the connector (pushing on it with a screwdriver to reseat it seems to make the problem go away for a while); mostly I REALLY don't like having my engine's only timing reference in between the block and the water pump with no way of cooling its internals. What do I have to change to put a vented Opti on my motor?
Old Jun 28, 2006 | 11:14 PM
Firebat's Avatar
i dont know but i know where you can find the answer...
CamaroZ28.Com Message Board
and if you're going to go through all the trouble, look into aftermarket optisparks from like MSD and ACCEL, that site has info on that stuff too
Old Jun 28, 2006 | 11:15 PM
mliers's Avatar
Car: 1992 Camaro
Transmission: Auto :(
Axle/Gears: 94 Formula rear end with 3.42s
Optispark Swap Page
Old Jun 28, 2006 | 11:22 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
When I replaced the optispark in my old 94 T/A, the cap I bought from ac delco was an updated vented version.
Old Jun 29, 2006 | 12:15 AM
dbrunner2's Avatar
Car: '89 Camaro RS
Eeek...different cam, timing set, and timing cover? Seems like I'd be better off adding vents to my current Opti. Urbanhunter, did you buy a whole new distributor, or just a new cap? Maybe there is some kind of venting provision on mine that I missed, if replacement ones are coming with that. If you just got the cap, maybe it's possible to use a vented cap with non-vented guts and base?
EDIT: Just looked at the MSD unit, p/n 8381. I never realized MSD made one for the 93-94 motors; looks like this is the answer. Probably $500 well spent, now I just have to wait for my next paycheck...
Old Jun 29, 2006 | 12:00 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Best thing is to go ahead and do the swap to the '95 opti. 1. you get rid of that splined opti that can be put on wrong and replaced with a pinned unit that can only go on one way. 2. The '95 was the biggest stock cam for the F-body LT1's and you can pick up a few hp doing this.
The MSD unit for the '93-94 model motors are still non-vented units.
Old Jun 29, 2006 | 01:31 PM
dbrunner2's Avatar
Car: '89 Camaro RS
MSD's manual for the 93-94 replacement (http://www.msdignition.com/pdf/8381_frm27275.pdf) says that it has a vent, and comes with a vacuum harness, which it has pictures of being installed. Maybe it was listed as fitting originally non-vented applications?
How is it possible to put the spline on wrong? I seem to remember that it was keyed to prevent that...
Old Jun 29, 2006 | 08:50 PM
Klortho's Avatar
Car: 1987 GTA
It may be keyed, but trust me, it's been done before.
Old Jun 29, 2006 | 10:18 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
'94 B and D bodys got late style vented opti's as well, and yes, the earily style CAN be put on wrong
Old Jun 30, 2006 | 09:56 AM
dbrunner2's Avatar
Car: '89 Camaro RS
How do you get it on wrong--shove the spline into the cam sprocket/distributor without lining up the missing groove on the shaft with the missing tooth on the sprocket and distributor?
Hawk, that's correct, I noticed that the MSD p/n 8381, the early style optispark replacement, fits on 92-94 corvettes, 93-94 F bodies, and 92-94 full size pickups, whereas their p/n 83811, the late style optispark replacement, fits on 95-96 corvettes, 95-97 F bodies, and 94-96 B/D bodies.
Old Jun 30, 2006 | 07:09 PM
Coach Hawk's Avatar
I believe the earily opti has many splined on teh shast like the water pump does. It does not have the single keyway like the late opti. That's my understanding anyway. I could be wrong.
Pac J
May 17, 2020 10:44 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
L0tuS
Sep 4, 2015 11:16 PM
