another lt1 engin problem please help
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Ok the car was running fine today and then the tack started to bounce from about 800-1000, and the car ran like ****. And then the car started to miss pretty bad. the car starts but does not idel right. Then if I drive it it will accelerate (but lacks some power) untill I reach a constant speed and then it brakes up pretty bad untill I get deeper into the gas, and then the same thing at a constant speed it brakes up agin.
I bypassed the electronic ignition box and ran off the oppti with the same result. When I first started it up it ran fine and when it went into closed loop it started missing.
Also I scanned the engin and tranny and found no codes?
Aweek or to ago I had a problem with the idel surging. I scanned it and found the tps code I cleared it and it ran fine till today? Could it be the tps, but I am getting no code or mill light.
Any hellp will be greatly appriciated!
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Check all your plug wires. I had this happen when I first got my LT1 running. Number 6 had come loose and was preventing spark on that cylinder.
Car: 1990 Formula
Engine: 95 LT1
If the tach is bouncing it is either an ignition problem or wiring. Make sure all ignition connectors are tight(opti, module and coil) and check your grounds. A bad TPS could cause a miss, but I don't think it would cause the tach bouncing.
Car: 1987 firebird
Transmission: 4l60e
If the throttle vpltage is spiking or at the wrong range it would tell the computer that it was throttling up or down, I think....
If I am running an electronic ignition and using the opti as a trigger could the opti still cause problems?
Car: 1987 firebird
Transmission: 4l60e
the opti is there just not used to control or deliver the spark, The aftermarket ignition box doest that and uses the opti as a trigger, like a crank sensor.
Car: 1990 Formula
Engine: 95 LT1
What type of ignition are you running? The only one I can think of is the LS1 coil conversion or the one that uses Olds Aurora coils.
Car: 1990 Formula
Engine: 95 LT1
Unless they have come out with a new one the crane still uses the opti. It is an ignition amplifier that only boosts spark. The computer still relies on the opti for a signal. A bad opti can cause those symptoms.
Car: 1990 Formula
Engine: 95 LT1
Check your timing with the scanner. It can help locate opti problems. If the RPMs on the scanner don't jump aroung, you could have a faulty tach or tach wiring.
