LT1 help Please
Old Jul 15, 2006 | 10:20 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
LT1 help Please
Trying to buy a LT1 the fellow says it's out of a vett witch I really dont want it if so. So I got him to get the #'s off the block looked them up said it was 92-up LT1 2 or 4 bolt I know all vetts where 4 bolt witch other way can I tell what year it is?
Old Jul 15, 2006 | 10:43 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Not sure how to tell exact year, i know 93 Lt1's were speed density and not maf so u could ask if it has map or maf
Old Jul 15, 2006 | 11:06 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I belive that the cam is different in the earlier years, check the cam #, but I could be wrong. Also 95 and up had the vented opti.
Old Jul 16, 2006 | 12:42 AM
Car: 1987 firebird
Transmission: 4l60e
Here is a little more info:
"You can deteremine what year the engine is by looking at the front of the engine. A "vented" Opti, and not crank position sensor is a 95. An unvented Opti and no crank position sensor is a 94. A vented Opti and a crank position sensor is OBD-II 96/97".
Old Jul 16, 2006 | 01:15 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The 92-93 doesn't have a front fuel crossover on the intake.
Old Jul 16, 2006 | 08:27 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The 'vette LT1s have the fuel lines on the passenger side of the motor where as the F-body and other ones are on the driver side. Block castings are the exact same between the 2 bolt and 4 bolt blocks which won't help, as stated above, the opti is vented on the '95 and '96 versions, '96 will have a different timing chain cover.
Rebuilding the Chevrolet LT1 Engine, Doug Anderson, Automotive Rebuilder, September 1999
All you will ever want to know about an LT1.
Old Jul 16, 2006 | 09:28 AM
Car: 1992 camaro
Axle/Gears: 3:73
ok thanks guys
Old Jul 16, 2006 | 01:13 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
96-97 has two knock sensors and a crank sensor on the bottom of the front cover.
Old Jul 17, 2006 | 07:05 PM
Car: 1992 camaro
Axle/Gears: 3:73
Ok I have some pics looks like that the fule lines are on the drivers side If any one would take a look at them to see if they might know???
Old Jul 17, 2006 | 07:36 PM
Klortho's Avatar
Car: 1987 GTA
It looks like a '93 model since it doesn't have the crossover in the front of the intake but in the rear.
Old Jul 17, 2006 | 07:40 PM
Car: 1992 camaro
Axle/Gears: 3:73
OK Thanks ALOT for your help!!!!!
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
