So tell me...
Old Jul 18, 2006 | 10:54 AM
Cerberus2k7's Avatar
Car: 99 Ford Ranger
Engine: 3.0 Flex Fuel V6
Transmission: The kind you have to change by hand
So tell me...
If I swapped in the fourth gen dash and possibly steering wheel, how much of the wiring harness would I have to modify?
Old Jul 18, 2006 | 11:36 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Here
https://www.thirdgen.org/forums/body...-exterior.html
And here
https://www.thirdgen.org/forums/body...ring-good.html
Old Jul 18, 2006 | 05:00 PM
Firebat's Avatar
I did the LT1 swap first and then months later, the dash swap. I had a Z28 LT1 and a Firebird dash so I had to wire them as two separate projects anyway.
I would wire them separate, one project at a time. You're going to have to shorten the harness quite a bit anyway and customize it, otherwise you are going to have your interior LT1 wire harness folded over a couple times and just have one big mess.
If you want to tackle both projects at once, wire up the LT1 first. The benefit of doing both the projects at once would be the dash not being there, allowing better access to the wires.
I dont know anything about steering wheel swaps.
Old Jul 18, 2006 | 09:07 PM
Car: 99 Ford Ranger
Sorry, I meant LS1 harness. And the way it's looking, this is going to be a flat out project car. Not gonna need to drive it around too much, so I figure I should kill all the birds with one stone.
F0xBody50
Theoretical and Street Racing
50
Jan 4, 2002 07:46 AM
ChillPhatCat
Sep 16, 2001 11:15 AM
Xenodrgn
Aug 23, 2001 08:11 AM
1990 IROCZ
Jun 13, 2001 08:46 PM
LV V8
Jan 7, 2001 10:27 PM
