some one got a secret to this?
Old Aug 14, 2006 | 10:27 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok so im putting the ls1 swap motor mounts on my cross member. and you have to some how majically put the nut on the end of the bolts. any tricks you guys got?
would be greatly appreciated.
Old Aug 14, 2006 | 11:10 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Try putting the bolts in from the bottom. This works for stock mounts.
Old Aug 15, 2006 | 08:55 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Take the A-Arms out. I ended up doing this and I think I saved some time by doing it lol.
Otherwise, a bunch of knuckles, extensions, a few choice words and a good back.
Old Aug 15, 2006 | 09:33 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
IIRC, there are a few bolts still hard to get to even with the A-Arms out. Just get a closed end wrench that fits the nut and tape it on one side.
Old Aug 15, 2006 | 09:56 PM
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
i figured out a way!
a nice retractable pen magnet works great. stick the nut on it and if you gentle enough rotate the bolt by hand and the nut starts then use a wrench to get a hold of the nut for tightening.
thanks for all your help.
Gta-Paladin
Dec 10, 2001 12:48 AM
daniel dekay
Dec 8, 2001 09:55 AM
Willie
Nov 5, 2001 12:37 PM
TomP
Oct 31, 2000 01:06 PM
