which T56 crossmember?
Old Jan 14, 2007 | 08:39 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I am deciding on either a Spohn or a Skulte. The price difference is negligable but I have read here that Spohn delivery time was way to long. Does anybody know if this has been fixed. I need the crossmember in the next two weeks so I can have everything to do the swap.
This will be for a 97 T56 in an 86 Z.
Old Jan 14, 2007 | 01:58 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I got my Spohn crossmember in under a week. Fits well and no problems at all with it.
Old Jan 14, 2007 | 03:00 PM
ssean92's Avatar
Car: sold
if you have a lowered car the spohn isnt the best choice, i hit it on everything
Old Jan 14, 2007 | 03:37 PM
Stevo's Avatar
Car: Pair of 92 Z28s
My spohn crossmember took under a week to get here, and also ditto to what was said above it definently is the lowest hanging part on my car and it hits speedbumps a lot. Its a scary noise when it scrapes and everytime i hit a bump my teeth clinch lol.
Also if you have alston SFCs they may interfer where it mounts. If you ever run a true dual exhaust system it looks like it would be hard to clear.
Old Jan 14, 2007 | 05:13 PM
Klortho's Avatar
Car: 1987 GTA
However there is a way to fix that......take a grinder to the piece that hangs down. That's what has been done to a few so it would clear.
Old Jan 14, 2007 | 10:13 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
jsut run a y with dual cutouts
im going to be using the spohn version
Old Jan 18, 2007 | 09:12 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Dont forget about drews crossmember... That seems to be the next best choice next to the spohn. Running exhaust is easy, seems to clear things well. However you cant run a crossmember mounted torque armwithout adding the bushing mount. But thats no biggie.
My vote is spohn if you are just needing a basic crossmember.
Justin
Old Jan 22, 2007 | 02:30 PM
ssean92's Avatar
Car: sold
i have been scared to modify this due to dont want to weaken it
Old Jan 22, 2007 | 02:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the drews design crossmember is the best choice out there IMO....
the only reason everyone cant run one, is that some people have torque arms that mount to their crossmembers.
Old Jan 24, 2007 | 09:38 PM
net_coma's Avatar
have a link to drews crossmember? I have the t56 and stuff but still need the crossmember. mine is lowered and the nose already drags on the driveway and everything between exit and entrance.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
kammi10
Nov 9, 2015 08:28 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
