Got donor car, what's left?
Old Mar 1, 2007 | 11:15 PM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
Just picked up a 95 LT1 Camaro as a donor car. I am goin to swap it into my 91 RS. IS there anything else that I am going to need that will not come with the donor car? The donor car is complete and is running.
Old Mar 2, 2007 | 09:08 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
If the LT1 is going in the V6 car in your sig you will need motor mounts and the matching clamshells for a V8 car.
Old Mar 2, 2007 | 08:16 PM
Bad-Newz's Avatar
im actually debating as to which car I wanna do the swap with. I keep hearing that the torque tiwsts the t-top cars but in my case in the one i drive most of the two... And what exactly are clamshells? I been doin the searches on here abotu the LT1 swap and there are so many variables that make it hard to get a simple answer answer to a question. I figured it would be easier to just pick up a donor car but its hard to get an answer as to what will be needed that won't be on the car...
Old Mar 2, 2007 | 08:47 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
torque does twist unibody cars add subframe connectors and you will be fine dont listen to people that say your gonna wreck your car if you do it it dont matter if u have t tops or a hard top they all flex no matter what u need to go to the parts store tell them u need motor mounts for a v8 fbody
Old Mar 3, 2007 | 12:25 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
The clamshell is the solid metal part that bolts to the block. It is either a junkyard or dealer item. They are the same(I believe)for all 82-92 F body V8s. What are the other questions you have? I will try to answer any that I can.
Old Mar 3, 2007 | 10:15 AM
mikesz1984's Avatar
Car: 1984 z28
i believe you will have to do some suspension work in the front end of your car, going from a v6 to the lt1 will mean you need v8 springs from a 3rd gen.
Old Mar 3, 2007 | 02:11 PM
Firebat's Avatar
Make sure you read this over: https://www.thirdgen.org/forums/ltx-...questions.html
Basically need fuel lines, power steering lines, custom a/c lines, V8 suspension, possibly radiator hoses, new V8 motor mounts then whatever for whatever tranny goes in.
Put the LT1 in the hardtop. Put in subframe connectors but make sure you have the frame checked before you put them in. I didn't check out my frame and when I get it checked out this summer and if its not straight, I'm going to have to re-do the sub-frame connectors. Which means, grinding them off and welding them back on.
Old Mar 4, 2007 | 06:36 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Put SFC's on the t top car if you are worried about it. Geez people a stock LT1 isn't going to pop the windsheild out of the car.
Old Mar 4, 2007 | 07:27 PM
Bad-Newz's Avatar
Im ok with with suspension stuff, engine and transmission, but the computer, wiring, and the fuel lines and otehr lines etc. Im stil a bit confused about. Iv'e been threw the boards and I've seen a number of members who have done this swap and have very clean lookign installs. Looks almost stock so I figure, if i'm going to ditch the 6, might as well go for the newer stuff. This will be however, my first swap AND my first car... So my hand's-on ability is limited at best. But i've also heard paying a shop to do the swap for me will cost more than a good chunk...
1992 Trans Am
May 10, 2023 07:19 PM
kyleb24
Aug 15, 2015 08:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
