3rd gen Ls1 swap power steering lines????
Old Mar 2, 2007 | 01:14 PM
00turboT/A's Avatar
I have an 88 Iroc Z that I put a Ls1 in from a 2001 T/A and was wondering what lines you guys are using for the powersteering lines????? Like what part numbers or what they came off of.Also some pics would be nice of them. I found this one but can't get any info on them but these look good.
Old Mar 2, 2007 | 01:33 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Stock LS1 power steering lines work fine That looks like them in that picture. You have to tweak the metal portion of the lines a bit...but they will work. Fittings are the same and all... Im pretty sure thats what everyone is using. Thats what I used...it was nice not having to piece lines together to hook it up. Just watch the pressure line, it gets close to the pulley. Thats where the tweaking comes in.
Justin
Old Mar 2, 2007 | 01:40 PM
Car: 86 Trans AM
Found a picture of mine. Its a messy in progress pic...
Old Mar 2, 2007 | 02:08 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the 99+ fbody ones fit like the pic you posted.
in that pic you you posted, thoes ARE fbody lines..
see that line that goes by the pulley? thats the tight spot.
now, whoever did that pic, was stupid and ghettoed zip ties for clearance.
all you have to do is tweak the hardline with your hand, and you have plenty of clearance, without spaceage co-polymer variable circumference fasteners.
oh, and for the low pressure return line... use the stock thirdgen box side, and then just power steering hose between that and the bung on the bottom of they reservoir... that way, you only have one big metal line sticking up rather then two.
Old Mar 2, 2007 | 08:54 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Stock 3rd gen lines work as well....just need to tweak them.
Old Mar 12, 2014 | 01:51 AM
Scarebird's Avatar
Car: 1998 Z28 convertible
Transmission: 700-R4
Re: 3rd gen Ls1 swap power steering lines????
good to know.
Old Mar 12, 2014 | 07:05 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I used the stock 4thgen LS1 high pressure hose, I had to bend it slightly. For the low pressure hose I used a V6 4thgen hose and cut it off shorter for a better fit/more direct route.
Old Mar 13, 2014 | 12:27 PM
BADNBLK's Avatar
COTM Editor
The routing on the stock third gens looks nice to me. Nice to have options.
Old Aug 7, 2020 | 08:04 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Attachment 447455
FYI - the stock hose will require major rebending to fit (not just tweaking) and the routing of the steering hose in this picture won't work. I installed a new stock hose same way as this picture and then it was in the way when I installed the serpentine belt. I was able to make the hose work with some more bending. Here's some pictures.
New PS hose installed like picture above with serpentine belt on:
PS hose with more bending to clear the serpentine belt:
Old Mar 24, 2024 | 10:17 AM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
I assume those are aftermarket cooler/lines b/c my OEM sits up so much higher off the pump above the framerail. I like the look of these and how you have them laid out. I know this was over 3 years ago but do you rememebr the cooler line parts?
Old Mar 24, 2024 | 10:41 AM
battmann's Avatar
the steel cooler lines (the two on the right side of the picture) is the factory setup. i took them from a 1984 TA L69 car. not sure if these lines were specific to that engine option.
Old Mar 24, 2024 | 02:06 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Old thread, but what the heck. These lines are from my 84, transferred to my 89. The hi-side requires the most re-routing, but can be done.
Old Mar 31, 2024 | 08:16 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I made my own using aeroflow PTFE AN hose. Works perfectly and you can make them fit perfectly.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
reiderz iroc
Aug 13, 2015 04:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
