Gauge wires
Old Mar 2, 2007 | 03:39 PM
Phoenix1987's Avatar
Car: 1987 Trans Am
Axle/Gears: 4.10's
Gauge wires
My aftermarket harness has a speedo and a tach outputs. They are single wire leads. As most of you know, the inputs for the gauges are two wires. How do I get these hooked up to work? I still have the plugs on the stock harness (Which have two prongs on the plug). Do I cut them off and hook up all three wires? (The 2 from the body harness and the one from the ecu harness?)
Thanks alot for the future help!
Old Mar 2, 2007 | 09:57 PM
dingle's Avatar
Car: '83 Camaro
Aren't the gauges 3 prong? Power, ground and signal. I replaced mine with autometer gauges but I remember screwing around with the original ones for a bit.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
