Keeping VATS
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Keeping VATS
Is it possible to keep the VATS in an Engine swap. I know in my 91 GTA and my buddies 95 LT1 our key blanks are the same just the resistor chip in the shaft of the key is different. So if you got the key to your new engine could you not have new set of keys made up with new engines resistors but your ignition locks key pattern. Only reason i ask is cause Fbodies without VATS are in the top 15 vehicles stolen every year in my area. And if i were to swap engines ever i think id want to do the little extra work to always wake up to my car in the driveway. Also just wondering what years have the resistor chip in the keyshaft approach.
Re: Keeping VATS
yeah its possible if its wired up if you use the 4th gen vats, i don't know about the thirdgen vats.
The easiest way would be to swap over the steering column from the LT1 parts car and wire up the 4th gen "vats box".
Another way would be to get a blank key with the correct resistor value and have it cut to match your key in your thirdgen steering column. You would also use the 4th gen "vats box".
Car alarms aren't too expensive either, if you install them yourself.
Car: Camaro
Engine: 6.2L
Re: Keeping VATS
Use a VATS bypass module and wire it in a handy place with a connector. When your leaving the car somewhere sketchy just unplug the module and take it with you. The modules are small... as in alarm fob small and they are only $40 bucks
Car: Pontiac Firebird T-Top
Engine: V6 3.1 170HP and LSX swap in mind
Transmission: TH700-stock
Axle/Gears: 3.23 -stock
Re: Keeping VATS
I thought the Starter is still protected by the original 3rd gen VATS despite a disabled VATS in the Engines PCM?
Car: Camaro
Engine: 6.2L
Re: Keeping VATS
I dont know how the 3 gen VATS works either but i wouldn't use it as I have seen many many posts from others having issues with it. The LS1 VATS cuts fuel and is simple yet effective.
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
Re: Keeping VATS
so i can swap in a 94-95 lt1 and leave the pcm stock... get this box for 40$ and the engine will run in my car??? where do i purchase said box?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Keeping VATS
you do not have to disconnect vats.. you do not have to swap vats.
if you wish to do nothing, you can disable it in the PCM, and it still works as a starter disable.
if you wish to use it to your full advantage, you just have to connect the ONE vats signal wire that used to go to your stock ECM, to the new PCM.
Car: 89 TA
Engine: 305 TBI
Axle/Gears: 10 bolt 3.08
Re: Keeping VATS
this is correct.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: Keeping VATS
Originally Posted by rmmstnr
Also, anybody know more about this, just for the heck of it?
