swap question and pics of H/C LS1
Old Sep 29, 2007 | 07:04 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
So finally have some time to continue the project. Here's the engine, Patriot Stage II heads, 59 cc with TR 224 cam on a 114 lobe, LS6 intake ported TB....
Now here is where i stand as far as wiring, which i would consider my leat knowledgeable area. Is there anything I have to keep from under the hood or can i just start ripping everything out. i'll be using a 4th dash w/AC eventually and I'm waiting on getting my LS1 harness back from lt1wiring. They will be extending, removing unnecessary wires and adding relays to make it stand alone.
Old Sep 30, 2007 | 09:39 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: swap question and pics of H/C LS1
Looks like that is gonna to be fun to drive
Old Sep 30, 2007 | 03:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I know I'm a little slow and pretty dense, but I'm confused - what do you mean in your subjectline by "pics of H/C LS1"?
Old Sep 30, 2007 | 04:08 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
H/C LS1 = Heads/Cam modded LS1
sorta like we mustang guys saying H/C/I for heads/cam/intake
lingo from ls1tech coming this-a-way it seems.
Old Sep 30, 2007 | 06:28 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
definately lingo from LS1tech but i stay true to TGO!!! i was going to buy a 4th gen SS but i deceided to build my 83 instead and wait for the 2009 Camaro.
But yeah anyone have info regarding the stock wiring? I've searched and it seems as if most people rip everything out and just run the pink ignition wire and the power to the battery?
Old Sep 30, 2007 | 06:42 PM
five7kid's Avatar
Carryover from the old BB days of no bandwidth, I presume.
Just speak English, that's good enough for me. . .
Old Oct 2, 2007 | 11:05 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
So i found out that i can start from my stock computer and pull anything anything related to that, I'm just not sure as far as the relays that are under the hood on the drver's side. i believe they affect the power to the dashboard, wipers, headlights, etc?
Old Oct 2, 2007 | 05:44 PM
five7kid's Avatar
The relays don't. The harnesses below them do.
Old Oct 2, 2007 | 07:53 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Nice, having just put in my engine, I can sympathize with that whole "now what" feeling of an empty engine bay.
Looks like fun..
For wiring and the like I would highly recommend getting the helms manual for your car.. I have a master manual for my 82 and it have been invaluable..
Old Oct 3, 2007 | 01:20 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
I removed all wiring and such and kept only my heater control wires which come out from the middle of the firewall above the trans tunnel. My harness had pigtails for a fan relay, and fuel pump relay. so basically other than wipers, everything else i removed and kept the battery wires from my original harness to tap into power for the ls1 harness. pretty simple
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
