alternator hook up?
Old Dec 4, 2007 | 09:42 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
Engine: LS1, 426 rwhp 406 rwtq
Axle/Gears: 9" with 3.70's
alternator hook up?
car is a 92 camaro rs that came with v8/auto. i am putting a 02 LS1 from a TA. my question is what do i do with the factory plug from the 92 alternator. it has a red wire with a brown wire in the plug. the LS1 plug just has a small red wire. my new LS1 harness is a Painless, but it dont say anything about alternator hook ups. i guess the other factory red wire still goes back on the alternator, right? i'm just not sure about the plug part. thanks
Old Dec 4, 2007 | 10:43 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: alternator hook up?
The 92 plug is no longer needed. The red wire is eliminated and the brown one goes to your volt gauge. Double check that though its late and I'm bagged
Old Dec 5, 2007 | 09:13 AM
92ZZ3RS's Avatar
Car: 92 camaro rs
i've searched alot on here and ls1tech. the best i can tell, i need to do away with the red wire in the 92 plug and the brown wire i can wire it to the red wire coming out of the LS1 alternator plug with a 500 ohm resistor in line. does this sound correct? thanks.
Old Dec 5, 2007 | 09:17 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Yeah that sounds about right. If memory serves the 92 red wire loops back around to the + terminal on the back of your stock alternator to excite it which the new LS1 alt does not need. As for the brown wire I did the same hooked it up to the only wire small wire ( cant recall color off hand ) coming out of the alternator plug on the LS1 alt but I didnt put a resistor in mine... Seems to work fine though
Old Dec 5, 2007 | 11:45 AM
chevy_camaro_ss's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
Don't mean to but in but how would I connect that to an alternator. I need to purchase a pigtail for my conversion becaue it was cutoff and I was looking to get it from EIF connections but I only see one wire. Would that one wire go to the PCM or something else? How many wires should be coming out of the alternator?
Old Dec 5, 2007 | 11:56 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
In my set up I have two wires to the LS1 alternator. One pos+ from the battery to the back post on the alt simple enough. and one coming out from the plug on the LS1 alt ( cant recall color ) but it hooks to my stock third gen brown wire going into the C100 connector and it provides a feed for my volt gauge. Thats it
I used solder and heat shrink and spliced them. if you dont have the connector for your LS1 alt then you should be able to order that easy enough.
Old Dec 5, 2007 | 01:24 PM
Car: 1989 Camaro RS
So nothing hooks up from the alternator to the starter and what guage did you use from the battery to the alternator?
Old Dec 5, 2007 | 01:33 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I have LS1 battery cables. On these cables the big red pos+ goes to the starter. Bi-wired ( factory spliced ) right at the battery terminal is another lead I'd guess and say its was 10 or 12 gauge that goes from the battery to the post coming out of the back of the alternator. No other wire is nec from the alt to the starter.
Old Mar 28, 2009 | 06:36 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
my alt has a red to the starter sol another red at the bottom of the alt to the distribtion block witch goes to the starter sol then to the batt in the trunk and a brown to the volts meter and another tan and white to the fans relay (not in any more) but mine wont charge the batt. is that a bad alt ill have it cheacked tomorrow but feedback would help
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
raymondandretti
Sep 27, 2015 06:43 PM
