speedo hook up question
Old Dec 7, 2007 | 05:00 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
Engine: LS1, 426 rwhp 406 rwtq
Axle/Gears: 9" with 3.70's
1992 camaro, factory v8/auto. now has LS1/t56 with a painless harness. the harness has a vss wire that goes to something. that something is what i'm wanting to know. what do i hook that wire to? i've searched alot and found some answers but i am not clear on what to do. thanks guys.
Old Dec 7, 2007 | 05:13 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: speedo hook up question
The speedometer buffer box under the dash near the ecm has two brown wirees, one is the output to the speedometer, the other is the output from the buffer to the ecu.
Old Dec 8, 2007 | 10:48 AM
chevy_camaro_ss's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
So where does the connections from the VSS sensor on the T56 go to?
Old Dec 8, 2007 | 01:08 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The connections from the VSS are tied into the PCM. There is a Speedo output wire in the LS1 harness that connects to the speedometer.
Old Dec 8, 2007 | 02:04 PM
Car: 1989 Camaro RS
Would any of you know what wire is the one that connects to the VSS sensor and which is the one that goes to the buffer box?
Old Dec 8, 2007 | 04:49 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Just hook it up to one of the two, if your speedometer doesnt work then switch it, you cant damage it since the one going to the ecu wont be connected to anything.
Old Dec 8, 2007 | 08:36 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
'92 camaro eng. codes (T,F and 8) have a grey wire (pin D) @ connector C207 that goes to the IPC speedo for the 4000 Pulses per mile input
'92 camaro eng. code (E) uses a tan wire that goes right from the buffer box connector C2 pin "C" to the IPC speedo for the 4000 pulses per mile input
C207 is a 15 cavities behind RH side of I/P (near the pcm location)
the one side of the c207 connector will have two black flat connectors . the other side is white or clear and is one connector that the two fit into
hope this helps
Last edited by 88 350 tpi formula; Dec 8, 2007 at 08:54 PM. Reason: correct ecm to buffer
Old Dec 8, 2007 | 08:41 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
so my vss wire that is in my painless harness will hook to which brown wire? the brown output wire to speedo or brown output wire to ecu? also, is it tan or brown wires?
Old Dec 8, 2007 | 08:53 PM
Engine: ls1, LB9
I'm not sure what the "painless harness" colored wire is but..... since you have the VIN E Eng. which ever wire they have labled for a speedo output to your speedometer connect that wire to the brown wire pin location "C" at your buffer box near your pcm (you can disconnect that wire from the buffer while you are connecting your painless wire)
Old Dec 8, 2007 | 09:02 PM
Engine: ls1, LB9
as another side note this way will eliminate the need for the buffer box and the factory 3rd gen cruise control. you can remove this stuff and save room. then you can run the ls1 cruise with out the need for rigging up the 3rd gen cable and cruise to fit the ls1
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Please ignore the other posts, he's confused, probably looking at diagrams from earlier year vehicles on the buffer box, the buffer box which is under the dash near your ecm, yellow box, got about a 6 pin connector, one will go output to the speedometer, the other outputs to the stock thirdgen ecu, so you'll have to do a guess and check, it will work one way and not hurt anything the other if it isnt hooked up right.
Old Dec 8, 2007 | 09:03 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
so that wire wont be connected to the buffer any more, right? and i dont have cruise anymore anyway and dont want it either.
Old Dec 8, 2007 | 09:05 PM
Engine: ls1, LB9
correct.
just make sure it is pin c
if you ever want cruise it is real simple using the ls1 setup
Last edited by 88 350 tpi formula; Dec 8, 2007 at 09:14 PM. Reason: Automerged Doublepost
Old Dec 8, 2007 | 09:09 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
thanks!!!!!!!!!!!
Old Dec 8, 2007 | 09:18 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Thats correct, however the buffer isnt just for cruise in a tbi car, the buffer is built into the 7730 ecu's but the tbi ecu didnt get it, the buffer in a tbi car directly receives the vss's signal, it doesnt go into the engine computer from the vss like on a tpi, LT1, or LSx.
Old Dec 8, 2007 | 09:26 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
so how are you saying i should hook it up? this is confusing. sorry.
Old Dec 8, 2007 | 09:38 PM
Engine: ls1, LB9
here this shows the wire to your speedo
Old Dec 8, 2007 | 09:50 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Like I said, the wiring colors change by year, and may even be different between camaro and firebird. Heres the same diagram with the feed to the I/P being a brown wire, go figure smart guy..
https://www.thirdgen.org/forums/atta...-permanent.gif
Unplug the buffer box connector, figure out which diagram matches yours for the colors of the wires and cut the brown wires and try each if you have both brown wires, if you have a tan wire cut it and hook the vss output to it.
Old Dec 8, 2007 | 10:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Attached is the 92 speedometer wiring diagram, thank you have a nice day, input to it is brown.
Old Dec 8, 2007 | 11:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've removed the noise from this thread. If the original poster wants this unlocked, send me a PM. If it does get unlocked, I don't want to see any more personal attacks.
Old Dec 9, 2007 | 09:15 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
well i found the buffer box today and pulled it down to look at the wires. i did have 2 brown wires. i cut the one that was in "c" spot and wired it to my vss output wire in my painless harness. hope this works. i should be ready to start it up in about 2 weeks. i'm doing fuel lines this week. i am thankful that 2 guys on here was going out of their way to help me. it is much appreciated.
Old Jul 2, 2012 | 08:49 AM
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
Wondering if that worked or not. We're getting close to that point, too.
Old Jul 6, 2012 | 04:29 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
yes. worked good. been working ever since
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
