MAF ??
Old Mar 19, 2008 | 08:50 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
MAF ??
what does it mean when the car will olny idle when the MAF is unplugged?
Old Mar 20, 2008 | 03:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's bad?
Old Mar 20, 2008 | 04:10 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: MAF ??
Originally Posted by five7kid
It's bad?
Old Mar 20, 2008 | 05:58 PM
Engine: 5.8
Re: MAF ??
it is new
Old Mar 20, 2008 | 08:38 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: MAF ??
Originally Posted by 2kickassbirds
it is new
means nothing..... do you know anyone with a known good one? you may have other problems but I have had new out of the box ones that are junk
Old Mar 20, 2008 | 11:20 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: MAF ??
Yep - I know I'm not the only one who's learned to not take for granted that a new part is automatically good...
Old Mar 21, 2008 | 11:39 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Re: MAF ??
Second all mentioned above, if you have a buddy with one that works switch them out and see what happens..
also get some contact cleaner and spray the contacts in the weatherpack to make sure you are getting a good connection.
I have had a lot of new parts be worthless recently, kind of a bumber but seems to be happening more often.
Old Mar 21, 2008 | 04:17 PM
Engine: 5.8
Re: MAF ??
I took the one off my 95 and it has the same problem butt I found the prong was bent on my connector so I will put a new one on see how it works
Old Apr 11, 2008 | 06:48 PM
Engine: 5.8
Re: MAF ??
Ok I changed the connector and it was fine until I turned it off now it is doing the same thing
If I put the one out of my 95 in it has a coed 48 and will not run but when I put the one out of the 89 in the 95 it runs prefect what should I check next
thanks
Old Apr 12, 2008 | 05:45 PM
Engine: 5.8
Re: MAF ??
Ok so you should check for vacuum leaks before you start to post scurry but I got it, the canister line off.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
