Low oil sensor LT1
Old Apr 30, 2008 | 10:14 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Low oil sensor LT1
Do you guys swap this sensor over or do you plug it. If you dont have the low oil light?
I would much rather buy a plug than a 60 dollar sensor.
Old Apr 30, 2008 | 10:34 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Low oil sensor LT1
Typically just leave the old sensor in the pan, not connected....
Old Apr 30, 2008 | 10:44 PM
Firebat's Avatar
Just get a plug(unless you got a 4thgen dash swapped in). I can't remember if the low oil sensor throws a code and/or just lights up a low oil light in the 4thgen dash.
Old Apr 30, 2008 | 10:46 PM
BCdawg57's Avatar
I had already thrown away the old sensor a while back.
I know the dimensions i would need are 20mm x 1.5 x 15 - 20mm
anyone know where i can get a bolt that size?
Old Apr 30, 2008 | 10:50 PM
Firebat's Avatar
Well, if you can't find that bolt at an auto parts store or a hardware store, you may just want to buy a used sensor from ls1tech.com or camaroz28.com's message board classifieds. You may have to give $20 shipped for it.
Old May 1, 2008 | 08:28 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
If you can't find it in a boneyard or at a hardware store here is another option look at 180-22-405. That is the plug for the canton lt1 pan.. would work fine it is 9.99 however..
http://www.thunderracing.com/catalog...&vid=4&pcid=84
Old May 1, 2008 | 11:11 AM
BCdawg57's Avatar
Thanks. I will try boneyards first, but 10 bucks is not as bad as 60.
Old May 1, 2008 | 09:35 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
advance or napa. ask for a differential plug.
advance has them cheaper than napa. they have a ton of different sizes.
yellow and black packaging, locally here.
Old May 1, 2008 | 10:48 PM
BCdawg57's Avatar
I really wish you said that earlier...
Old May 3, 2008 | 01:39 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
does anyone know if you can put a resistor or anything in line to get rid of the low oil light on the 4th gen cluster.
i dont run a BCM, so the light stays on constantly.
midge54
Dec 27, 2019 04:14 PM
perZ
Aug 21, 2015 05:51 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
