changing spark plugs
Old Jun 23, 2008 | 01:31 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
how do you guys change the #8 plug on a ls1 swap when the ac box is still there.
Old Jun 23, 2008 | 02:40 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: changing spark plugs
I used a spark plug socket with a wrench. Its tight but it worked for me
Old Jun 24, 2008 | 06:42 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I might get that one from underneith. But Im sure I can get it from up top if I use a universal on the socket. Its definietly tight....however not as bad as the 4th gen guys have it. Atleast we can see ours from the top haha
J.
Old Jun 24, 2008 | 11:23 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
J.
I can't get my hand back there to even touch my plug just can touch the plug wire. I've changed them on the 4th gen plenty of times I can get them all from top. tight but can do it. I cant get my hand back there to even pull the plug wire off on mine...
Old Jun 25, 2008 | 11:49 PM
Car: 86 Trans AM
Just as a visual....here is how mine looks.
Without coils of course....That helps free up some space.
My hand back there... My middle finger is right on the back plug. If it was loose, I could spin it with my hand.
J.
Old Jun 26, 2008 | 10:45 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
how did you pull the plug wire off?
Old Jun 26, 2008 | 12:27 PM
Car: 86 Trans AM
I just give it a tug. I put boot grease in the boots.....they come off fairly easy. But if it gives me trouble, I imagine ide take a big flat head, and sneak it down there, get infront of the boot and wiggle it off. There are also boot "tongs" you can pick up at autozone or napa... They kinda help, but Ive never needed them.
J.
eightsixseven
Dec 16, 2024 01:50 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
