i need some help??!!
Old Aug 12, 2008 | 10:04 AM
timeflyere6's Avatar
Car: 1992 camaro rs 25th aniversery
Engine: crapy 305 tbi
Transmission: blown 700r4
Axle/Gears: stock
ok i have weighed my ideas and decided to buy a ls3 engine for my swap. i been looking up adons an things and have found u can roughly get 900hp at about same torque my prob is i cant find a trani that i can put in that would suport that at least thats automatic, i dont know how to drive stick....lol and i dont want to have to do any conversion from auto to manuel. I know that i wont have that kinda power for a little time but i dont want to have to change my trani again so can any one tellme what tranies will fit and can deal with that power?. I have looked at automatic 6spd but i dont know if it would fit or bolt in any help be grate
Last edited by timeflyere6; Aug 12, 2008 at 10:11 AM. Reason: computer didnt let my type lol
Old Aug 12, 2008 | 11:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
First question: What do you plan to do with the car with that kind of power?
Old Aug 12, 2008 | 11:48 AM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Re: i need some help??!!
I would say you should tough it out and learn how to drive stick and do the conversion. Your life will be a million times better if you do this. Trust me.
Old Aug 12, 2008 | 04:33 PM
Axle/Gears: stock
i prob should.. and what do i plan to do with that power well its going to be a show car and a track car on ocasion but im not racing her i just want to be able to say hahaha my car has x hp and u dont
Old Aug 12, 2008 | 05:28 PM
Axle/Gears: stock
ok and if i learned to drive stick... what tranni could i use that would fit my 92 camaro and bolt to an ls3?? plus handle high power
Old Aug 12, 2008 | 06:06 PM
five7kid's Avatar
In order to even be allowed to go down the track, you might as well plan on a roll cage. Since you're going to have to do that, "fit" isn't going to be in your vocabulary, since you're going to be fabricating most everything, anyway. 900 HP is a BUNCH of power, and you need to plan carefully everything needed to handle it. "Tubular" and "custom" will be a big part of your new vocabulary.
Old Aug 12, 2008 | 07:45 PM
Axle/Gears: stock
yeah i figured that lol i aready been planning on bying sophn's tubular cradle set up and frame rails. but i been trying to figure the right way to run with this. so far 6l80e i looked at only handles 450tq but I see that a 4l80e can be made to handle 1000 hp?? would that bolt onto an ls engine and how well does it fit I mean will I have to custom a lot of parts to put this trani in?
Old Aug 12, 2008 | 07:51 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
First off, how much money do you think it'll cost to do that?
Second, given your current income, how long will it take for you to get that much money?
I can lay out a step-by-step "recipe" that will result in that much power (or pretty close to it), but I want to see the answers to the two questions above first...
Old Aug 16, 2008 | 12:37 PM
sroka's Avatar
Powerglides and TH400 will handle that power. I've seen very few 900hp LS3s
