LT1 no start no spark 2 opti AHHH!!!
Old Aug 14, 2008 | 05:21 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
I am begining to get extremley frustrated with this engine. I swaped a 94 into my 91 camaro.
My problem originated with no spark. I had a brand new wiring harness, brand new coil, a tested good ICM, brand new GM opti, a computer ive never witnessed running.
I did shoebox's opti test, and wasnt getting any AC pulse at the ICM connector. Replaced the opti, and i still get no pulse. I have .4 volts ac at terminal b constantly with the key on. Everything has the power it should.
My computer was tuned by trifecta, which uploaded flawlessly, and when i used his tuner as a scanner i first got code 42, and then code 16. that is when i replaced the opti. Now right now i have no acess to a scanner, but as i said im still getting no ac pulse. Right before i shipped the scanner back i did pull a code 42 again, but didnt think anything of it cause of misc plugs that were probably disconnected. Possible my PCM is bad?
Im at a loss and i dont want to spend 200 on a hunch.
Old Aug 14, 2008 | 07:25 PM
ssean92's Avatar
Car: sold
Re: LT1 no start no spark 2 opti AHHH!!!
do you have the ground connected by the starter?????
Old Aug 14, 2008 | 07:29 PM
BCdawg57's Avatar
im not sure what you are talking about.
Old Aug 14, 2008 | 07:35 PM
ssean92's Avatar
Car: sold
this one that says ground to block
Old Aug 14, 2008 | 07:39 PM
BCdawg57's Avatar
Oh, well i have an aftermarket harness, and the pcm ground is grounded on the firewall.
Old Aug 14, 2008 | 07:40 PM
ssean92's Avatar
Car: sold
what harness
Old Aug 14, 2008 | 07:43 PM
BCdawg57's Avatar
speartech
Old Aug 14, 2008 | 07:55 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
What coil do you have on it?
Old Aug 14, 2008 | 08:14 PM
BCdawg57's Avatar
the msd. it wouldnt be the coil though because im not even getting a pulse from the computer. right?
and i just tested the ohms on the 4 wires on the opti harness to the computer, they all read 0.00 ohms.
Old Aug 14, 2008 | 10:03 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
It may be worth trying to find a stock LT1 harness and trying it....
Or give Speartech a call.
If the ignition wiring isn't hooked up properly, you will get a no spark, might want to also make sure the pinouts on the PCM connectors are for the PCM you have, they changed between years, especially if you still had the C100 connector on the harness.
Old Aug 15, 2008 | 10:16 AM
BCdawg57's Avatar
Maybe i wasnt clear, but im getting good connections between the opti and the computer. I just dont know if this new opti still isnt pulsing or if the computer has a short and wont signal the ICM.
Old Aug 15, 2008 | 12:20 PM
Klortho's Avatar
Car: 1987 GTA
have you swapped out the pigtail on the opti?
Old Aug 15, 2008 | 02:04 PM
BCdawg57's Avatar
Well dont i feel like an idiot.
Yesterday i tested continuity from the end of the opti harness, back to the black connector on the PCM and read good on all 4 wires. Today i decided to do the same to the ICM. pin B5 on the PCM was Ignition Control, a white wire. The wire on the ICM side was lt green, so im like wtf that doesnt make any sence and obviously i had no connection when i tested it. So i call speartech and ask them what the deal is and he goes through the skematic with me and tells me which wire it should be. I tell him i get nothing when i test it with an ohm meter, and the colors of the wires. He then procedes to tell me that i had the IAT plug plugged into my ICM this whole time and the ICM pluged into the IAT.
Needless to say as soon as i switched them it fired right up!
Old Aug 15, 2008 | 04:11 PM
ssean92's Avatar
Car: sold
Glad to hear it......
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
Thirim
Aug 9, 2015 06:19 PM
