needing some lt1 swap info
Old Sep 2, 2008 | 06:14 PM
bmfIROC-Z's Avatar
well i think im about done playin with the 305 and i think im gonna do a lt1 swap ,i was just wondering if my 700r4 would work with the lt1 setup?where could i find a complete lt1 swap for a decent price?and is this a pretty easy swap to do or will i have to have some tuning done if i swap directly from an lt1 car to my thirdgen?any insight would be appreciated,thanks,joe
Old Sep 3, 2008 | 11:42 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: needing some lt1 swap info
The 93 LT1s used a 700r4, so you can use a throttle body from one of those cars to utilize the TV cable along with the LT1 throttle cable. Then again, you might be able to continue using your existing aftermarket throttle body and throttle cable. Maybe someone else can chime in on that one.
As for tuning, it all depends on what you do or don't swap over. If you don't keep the vats system intact by utilizing all the associated electronics from the donor car and swap the lock cylinder over, you will need to "tune out" the vats system. Overall, be prepared for A LOT of wiring! I learned a lot about the electrical systems doing my swap. If you want to do it, do lots of reading on here and look for wiring diagrams that are specific to your year car and go to shbox.com for wiring diagrams specific to the year of your donor car. I do suggest getting a donor car that's wrecked so you know you get everything you could possibly need from it. I did that and held on to everything related to the wiring of the car. While it isn't strictly required, for the purposes of making the wiring extra clean, I recommend keeping the interior dash wiring harness!
Old Sep 3, 2008 | 06:01 PM
bmfIROC-Z's Avatar
is ther anwhere on the web to find a wrecked lt1 donor car for a decent price?
Old Sep 4, 2008 | 06:58 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
I found mine locally on a local f-body site. If you have one of those, use it. If not, look at sites like camaroz28.com.
Old Sep 4, 2008 | 03:57 PM
ssean92's Avatar
Car: sold
Get a whole set up, dont mess with the 700r......
Old Sep 4, 2008 | 08:18 PM
bmfIROC-Z's Avatar
why whats the difference between a 700r4 and 4l60e?besides that the 4l60e is electronically controlled.
Old Sep 4, 2008 | 10:28 PM
TexasLT1's Avatar
Car: '92 RS
4L60E also came with the LT1 and simplifies the swap
Old Sep 5, 2008 | 05:03 PM
bmfIROC-Z's Avatar
ok well im not real worried about simplicity,id like to use the 700r4 i got cause i just baught it last year and it has like 10,000 miles on it with a brand new shift kit and wot upshift kit so i know its good,what would i have to do to use the 700r4 i got?and would my existing exhaust fit with the lt1?
Old Sep 6, 2008 | 12:48 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
https://www.thirdgen.org/forums/ltx-...ight=700r4+lt1
Should keep you busy for awhile. And I belive Firebat told me that is was not worth it in the end.
Old Sep 6, 2008 | 04:59 PM
bmfIROC-Z's Avatar
i see,well i think ill just sell the 700 when i get ready to do the swap.
Old Sep 22, 2008 | 09:59 PM
jdhogg86's Avatar
I run an 88 700 against my 93 LT1. I use the 86 style throttle body for my linkage, and "customised" the LT1 braket for my TPI TV cable.
The 4L60e will cost you money for a controller, or you have to run the factory computer. I run a gen6 DFI that controls the TC lockup, or you could just use a switch. Also, is your speedo electronic or cable? Just more to mess with.
A built 4L60e is only marginally srtonger at best that a built 700. Only benefit is increased line pressures at low rpm/load for forced induction b/c no TV cable.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
