some pics of my ls1/t56 swap
Old Sep 16, 2008 | 05:16 AM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
Transmission: 2002 T56
Axle/Gears: fabricated 9" w/ 4.11 gears
I had some free time and decided to post up some pics of my ls1/t56 swap that i finished up over the winter. I would like to thank everyone on thirdgen for all the help and let me know what you guys think.
Attached Thumbnails some pics of my ls1/t56 swap-notch.jpg   some pics of my ls1/t56 swap-xmember.jpg   some pics of my ls1/t56 swap-ypipe.jpg
Old Sep 16, 2008 | 05:17 AM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
Re: some pics of my ls1/t56 swap
some more pics
Attached Thumbnails some pics of my ls1/t56 swap-wires.jpg   some pics of my ls1/t56 swap-guages.jpg   some pics of my ls1/t56 swap-interior.jpg
Old Sep 16, 2008 | 05:19 AM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
more pics
Attached Thumbnails some pics of my ls1/t56 swap-dscn1821.jpg   some pics of my ls1/t56 swap-dscn1822.jpg   some pics of my ls1/t56 swap-dscn1823.jpg
Old Sep 16, 2008 | 05:21 AM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
some pics of my car
Attached Thumbnails some pics of my ls1/t56 swap-dscn1820.jpg   some pics of my ls1/t56 swap-dscn1824.jpg   some pics of my ls1/t56 swap-dscn1816.jpg
Old Sep 16, 2008 | 06:02 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Nice job! What are you running for a cat back? Is there any chance of getting some vids of it idling, and maybe some part throttle/WOT throttle runs?
Im asking because I see your y-pipe is similar to mine, and you have the random tech cats installed. Ive been toying with this idea for some time now, mainly to cut down on the rasp and refine the sound of my exhaust alittle bit. Just curious as to how different it sounds...youre one of the few to be running a catted Y I think...
Again...nice work!
J.
Old Sep 16, 2008 | 06:15 AM
AC's Avatar
AC
Car: Used to drive a camaro
Nice, not a bad job at all. I'm diggin the ground clearance you were able to come up with on the exhaust setup.
Old Sep 16, 2008 | 08:05 AM
Car: 86 Trans AM
Im convinced that the setups involve a double hump crossmember (bought or homebrew) and a custom y-pipe. I dont scrape on anything. I havent been over a speed bump yet that even touched a pipe.
IROCBMX did a nice job tucking it all esp with the cats included. Wish there were aftermarket solutions that fit as well as the custom ones...would have saved me a lot of time and headache. Good stuff!
J.
Old Sep 16, 2008 | 08:42 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Good job on getting it done!
A/C I'm jealous.
I started to put A/C in mine but the box just hogs too much room.
I run longtubes and true duals but use the double hump cross member and it gives awesome clearance, same as his pics.
The LS1 made it super quiet vs the 406 though. My car is quieter then a stock on I think.
Old Sep 16, 2008 | 10:00 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
How does the A/C feel using the R-134 compressor with the R-12 parts?
Im jealous too!!
Old Sep 16, 2008 | 02:03 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Count me in on wanting to know how the A/C worked out.
Also on how it tucked in. I am thinking of going this route.
Nice job.
Old Sep 16, 2008 | 02:38 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Congrats man you've got a very nice clean build there
Old Sep 16, 2008 | 03:56 PM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
Thanks on all the complements so far. To answer ghettocruiser's question, I would like to put up video clips of the car, but i don't have access to a video camera, but if a do i will. the cats do cut down on some of the raspiness though, as for clearence, i only scrap on tall speedbumps, but its not horrible. The a/c isn't charge yet, i brought it over to a shop a few weeks ago and forgot to install the orafice tube, so i fix that and will have to try again in maybe in the next few weeks, I will keep you guys updated. I also will be installing a midwest chassis sheetmetal fab 9" in the next couple of weeks and I will keep you guys updated with that as well.
Old Sep 16, 2008 | 05:06 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
That is a SHARP looking setup. Nice job.
1984HO
Mar 19, 2021 11:59 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
aaron7
Aug 17, 2016 06:02 PM
theshackle
Aug 22, 2015 06:52 PM
cstrobel65
Aug 15, 2015 10:19 AM
