Need some help lq4 to lq9
Old Sep 26, 2008 | 03:01 PM
lahotshot75's Avatar
I may be in the wrong place to ask this question but here goes. I am no engine expert by any means, i have an 03 chevy dually has the lq4 in it blew the engine and having to replace it. I know, or at least i think i know that the lq9 has more hp, i found lq9 out of 03 escalade can get total package with wiring and computer. Will i be helping things any by going to the lq9 im not so much worried about speed but i do alot of pulling just wondering what problems id have making the swap will everything bolt up, and will this engine work doing alot of pulling, i mean chevrolet had to opt to put the lower hp engine in the 3500 for some reason just nt sure what that reason may be... Thanks in advance for any help
Old Sep 26, 2008 | 03:20 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need some help lq4 to lq9
Originally Posted by lahotshot75
I may be in the wrong place to ask this question but...
Unfortunately, you are. TGO is dedicated to thirdgen Camaros and Firebirds.
JamesC
Old Sep 28, 2008 | 12:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
We have a section for the LSx family swap. Since the info might be of use to those considering one of those engines in their 3rd gen, I'll let it live there.
Old Sep 28, 2008 | 02:26 AM
Sorry for intruding in yalls space i guess i should have read more before asking. I dont know much about these forums was just tryin to find some advice from some chevy folks about these 6.0 engines before i make a mistake.
Old Sep 28, 2008 | 01:54 PM
007BALT's Avatar
Car: 91 Red Z28 G92 Spohn Suspn
Engine: 6.0/L92 Supercharged. Fully Built.
Transmission: 6L90E + G8 Shifter
Axle/Gears: 3.08
go to LS1tech.com, and click on the performance truck section on top.
Old Sep 28, 2008 | 10:23 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Hell, it's just as easy to answer the question as to point him somewhere else...
Given that the LQ9 is from the same year vehicle, it should be just about the simplest swap possible (I'd think that you'd even be able to keep the same engine wiring harness that you already have).
The only notable difference between the 4 & the 9 is that the LQ9 has a slightly higher compression ratio (because different pistons were used). This means that you'll have a little bit more torque/hp, which will definitely help you with your towing duties. Aside from the pistons, EVERYTHING ELSE should be the same - the block, the heads, the bolt holes, the accessories, etc. (that's what I meant when I said the easiest swap possible). It shouldn't be much more than a simple R&R type operation, although for best results you WILL want to use the LQ9's computer.
Throw a set of decent headers on that puppy when you're done, as well as a high-flowing muffler, & you'll probably be up 40 or 50 hp from what you had with the LQ4!
(And yes, PerformanceTrucks.net is probably the best place to find answers for your truck...)
Good luck, & enjoy the newfound power when you're done!
Old Sep 29, 2008 | 01:59 PM
007BALT's Avatar
Axle/Gears: 3.08
That is true, but i didnt know the diffrences, so i pointed him in the direction that would help, but thanks for the info.
1984HO
Mar 19, 2021 11:59 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Jynx88
Oct 4, 2015 08:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
