Identifing a lt1 or l99
Old Dec 4, 2008 | 01:27 PM
dbrew's Avatar
I recently purchased what was supose to be a LT1 out of a 96 Camaro. From what I've read on other sites I think I may have been duped and bought a l99. The #'s on the rear ledge are 43006 and directley under that SGI. On the side of the block it's stamped 588. Can some one more knowlegable than I confirm this.
Thank You
Old Dec 4, 2008 | 02:09 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Identifing a lt1 or l99
Look here: http://www.mortec.com/castnum.htm
Old Dec 4, 2008 | 02:36 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I think you're right, L99 but I doubt it came from a Camaro.
That # 4.3 is what is on the back after SGI gives it away.
Old Dec 4, 2008 | 04:26 PM
dbrew's Avatar
I bought the motor pretty cheap 600.00 complete with harness and computer so I'm not gonna cry over spilled milk. I'm currently running a 305 which is about to through a rod. But any way do you guy's think its better to run the l99 or rebuild the 305. Which will have more power?
Old Dec 4, 2008 | 05:29 PM
ssean92's Avatar
Car: sold
post pic of it, and if it has a standard looking wp it is not a lt1, that is a easy way to know
Old Dec 4, 2008 | 05:37 PM
danandamy's Avatar
Car: 86 Camaro
Is the distributer buried under the harmonic balancer/water pump? If so it's an lt1.
Dan
Old Dec 4, 2008 | 06:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"10168588...265...94-96...2...L99, Gen.II, 4.3 Liter V-8, Caprice, reverse flow cooling"
Old Dec 4, 2008 | 09:33 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Not that I'm trying to unsettle you or anything, but I wouldn't exactly call this spilled milk. You're getting screwed out of 85 cubes...if you paid for a 396 BBC would you accept a 305 SBC?
Old Dec 5, 2008 | 09:19 AM
dbrew's Avatar
Yea I definatley got screwed but there is not much I can do about it. Acording to every one I spoke to it is a L99. I started a Pay Pal dispute I'll see were it goes and keep you guys posted. Hopefully some one will read this and be more knowledgable than I was and not get screwed .From every thing I learned the engines appear identical on the out side but displacement and the heades are differant
Old Dec 5, 2008 | 10:56 AM
TexasLT1's Avatar
Car: '92 RS
that doesn't work here. The L99 is externally identical to the LT1 except for the different casting marks
Old Dec 6, 2008 | 06:39 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I thought the intake casting was differant.
Old Dec 6, 2008 | 05:58 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Only thing besides the rear casting numbers that make it easily identifiable from the LT1 is the number on the passenger (I think) side of the block. The LT1 says 327 whereas the L99 says 588. The intakes are actually the exact same part number and are completely identical. Same with the water pump and opti. The accessory brackets are different but you have to remove the accessories and the bracket to see that.
The fuel rails are also different but will work if you absolutely have to. Thing is, if you connect them to an LT1 car fuel line, they will NEVER come off unless you cut them off. I made that mistake on my old car.
Old Dec 16, 2008 | 08:20 AM
Pocket's Avatar
Car: 91 Trans Am
Not true
Fbody caprice/caddy Lt1 fuel rails are the same
You just need the quick disconnect tool
Old Dec 17, 2008 | 03:37 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Originally Posted by Pocket
Not true
That's what I would have thought because they fit together just fine. According to the guy that bought my car theres some special lip inside that won't let them comeback apart after they are assembled. Just going by what I was told and decided to error on the safe side.
Elephantismo
Feb 13, 2019 12:51 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
L0tuS
Sep 4, 2015 11:16 PM
