Flywheel - Difference between Corvette LT1 and Firebird/Caprice LT1?
Old Dec 16, 2008 | 09:19 AM
FBLT4's Avatar
Car: Firebird, Audi, Camaro
Engine: 5.7TBI, 5.7LT1, 2.8V6, 2.3I5
Transmission: 700R4, T56 coming soon
Hi all,
I have a fidanza flywheel part #198501 which fits the 1989-1996 Corvette LT1.
What is the difference between fitment to a Corvette LT1 and an LT1 from a Caprice? I understand Caprice LT1 vs Firebird LT1 the heads are iron vs aluminum and the cam is different. Would this flywheel fit, or no? I am thinking no because of 1 piece bearing vs 2 piece, but wanted to ask someone who would know for a fact.
Any one know for sure?
Old Dec 16, 2008 | 09:50 AM
Twin_Turbo's Avatar
Re: Flywheel - Difference between Corvette LT1 and Firebird/Caprice LT1?
That caprice LT1 has a 1 pc main seal crank too, it's the same basic roller block. The LT1 uses a dual mass flywheel.
Old Dec 16, 2008 | 09:22 PM
FBLT4's Avatar
Hmm interesting... Anyone have an idea why Fidanza made different flywheels for the two engines with a considerable price differential? ($50!)
#198501 1989-96 Corvette/13.5 lbs. [379.99]
(http://www.jegs.com/i/Fidanza/383/198501/10002/-1)
#198581 1993-97 Camaro/Firebird LT1/13.5 lbs [$429.99]
(http://www.jegs.com/i/Fidanza/383/198581/10002/-1)
Old Dec 17, 2008 | 07:48 AM
Twin_Turbo's Avatar
Hummm, there must be a difference then. Maybe gear teeth count? Might be the thickness also. Those vettes used a ZF6.
Old Dec 18, 2008 | 02:25 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Vettes used a ZF 6-spd, F-cars used the T56. I'll bet thats where the difference lies.
Old Dec 20, 2008 | 06:03 PM
FBLT4's Avatar
That could be... Does anyone know if I need to include the weight on the Corvette Fidanza flywheel to bolt it onto my 1995 Caprice LT1?
Old Dec 20, 2008 | 09:27 PM
Air_Adam's Avatar
What transmission are you trying to put behind this engine? If its a T56, then just get the F-car part.
Old Dec 23, 2008 | 09:39 AM
FBLT4's Avatar
The transmission is an T56 from a 95 firebird. Will it fit to a 95 caprice LT1 motor with this Corvette flywheel? I've been told it will work, just the Corvette flywheel is about a pound heavier for noise cancellation.
Does anyone know if it will work, and do i need to attach the removable weight fidanza included in the package?
Old Dec 23, 2008 | 10:43 AM
Twin_Turbo's Avatar
The ZF uses a pull style clutch, not a a push style. The flywheel shoudln't differ for that but maybe it's the bolt pattern for the pressure plate.
The removable weight is for an external balance engine.
Old Dec 23, 2008 | 09:40 PM
Air_Adam's Avatar
If they were interchangeable, then the manufacturer wouldn't have one for the F-car and another one for the Corvette. There is something different that makes them non-interchangeable. Get the T56 flywheel.
Old Dec 24, 2008 | 02:30 PM
Twin_Turbo's Avatar
Does the non vette application use a dual mass flywheel or does it use a normal one and a clutch with springs? It's either that or the ZFs pull type clutch.
Old Feb 4, 2019 | 07:45 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
This car is going to be hella fun! Those LT1s were very strong I always liked the way they pulled especially with the 6spd.
Old Feb 4, 2019 | 12:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
11 years later lol
Old Nov 26, 2020 | 12:07 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
did you just buy my superam?
Old Nov 27, 2020 | 05:16 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Yes.
Trickskier
Aug 29, 2015 01:12 PM
zayne0
Aug 24, 2015 07:22 PM
kah992
Aug 19, 2015 02:55 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
