Everyone with LT1!!!
Old Jan 10, 2009 | 07:52 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Hey guys i want to here your set up with your LT1. I would like to know how much power you are making and if you know your 1/4 mile time. I basically bought a LT1 from a 96 impala ss. I say basically bc they are holding it for me but its still in the car and they want all the money before they pull it. I dont like that deal. I was going to give them like 100 bucks then the rest once its done so i know all the wiring is good and not just cut. Any ideas? It is complete with everything for 500 bucks.
I know it is 260 hp and 330 tq. Why is that so much less than the camaro or corvettes? Should i get aluminum heads? What the difference in the engines? My goal with the engine is between 380-400 rwhp.
thanks
kevin
Old Jan 11, 2009 | 09:43 AM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Re: Everyone with LT1!!!
Im not exactly sure on the power difference. But a major role in it is most likely exhaust set up.
Old Jan 11, 2009 | 09:57 AM
jrs84ta's Avatar
Car: 1984 firebird
Engine: swapping lt1
That's a good deal for that motor. The difference in the power from the impala and the f-body motor is the cams that they have, and the impala has iron heads which some say flow better than the aluminum ones. Just get a cam from an f-body or vette and the power will go up.
Old Jan 11, 2009 | 10:15 AM
Ya it is complete with wiring and computer. I just dont want to give them all the money and they just cut all the wires to get it out fast u know. For my build i wanted to port and polish the heads to 2.02 and 1.6 have no clue how much money. Rebuild kit of course. 3000 stall with a hot cam mabey around .525-.550in lift. Then are the injectors big enough? Should i port out the TB to? Then headers and y-pipe. I'm hopin it wont be much over 3k.
thanks
kevin
Old Jan 11, 2009 | 09:32 PM
duncz's Avatar
Car: 88 Iroc
Man thats pretty ambitious for 3K. Prob. looking at least 500$ for the head porting.Exhaust ran me about $600 for headers, y pipe and cat back stuff. You dont really mention a tranny, but I never could get mine to run well with the 700r4. You are gonna need some ecm tuning, so the service or the cable/software will be a couple hundred as well. I felt like I took a cheaper route and I still spent almost 7K. I guess it depends on how much you can do yourself.
Old Jan 13, 2009 | 11:10 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
with bolts ons and a six speed my car ran 13.4 @ 104 with a crappy 2.2 60ft time. That was when it dynoed 289 rwhp I believe.. 3395lbs. I was thrilled that day since it beat a then new BMW M3 in the other lane(not the v8 version).
with the current heads and cam etc.. it is over 400 but I don't really go to the track and it isn't why I put the car together but I could guess if it would ever hook low 12s or high 11s..
Good price on the engine but don't forget the formula, more power=cubic dollars.
Old Jan 14, 2009 | 08:27 AM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
My best time was 13.2 @ 106. That is with Hotcam, 1.6 rockers, LT4 KM, and full exhaust.
Old Jan 14, 2009 | 08:34 AM
I want to be in the 12's. With my 3:73 and 3000 stall. I bought the motor last night! I pick it up thursday!
kevin
Old Jan 14, 2009 | 08:51 AM
Has anyone tried this cam? What do you think about this cam?
Comp Cams XFI LT1 Camshaft, 230 / 236, .576 / .570 113 LSA, Strong mid-range and top end power. Headers, exhaust, gears, converter, computer tuning recommended.
or this one?
Comp Cams XFI Camshaft, 210 / 218, .560 / .555 113 LSA, Good low end, with strong mid range power. Headers, exhaust, computer tuning recommended.
kevin
Old Jan 14, 2009 | 06:15 PM
Dose anyone know about them cams?
kevin
Old Jan 14, 2009 | 06:33 PM
iroc1793's Avatar
Car: 1987 Camaro Iroc-z
Engine: 305 tpi
Transmission: t5
kevin
good place to look for cam selection help is over on ltxtech or ls1tech
Old Jan 14, 2009 | 08:10 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Or camaroz28.com in the lt1 section.. you don't need much to run 12's just some traction and a good stall.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
