Post pics of LSX swap third gens
#101
Car: Check The Sig
Re: Post pics of LSX swap third gens
Why doesnt it work? It uses the same 16mm x 1.5 O-ring fitting as your stock PS pump did. Just thread it in there and bend it back slightly to clear the pulley
Should look like this
http://i150.photobucket.com/albums/s...1/DSC01690.jpg
#102
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
At altitude, ~8500' DA, 13.3's @ 104 mph. Closer to sea level, ~3500' DA, 12.4's @ 110 mph. Not too bad for a bunch of factory parts with "select" aftermarket pieces (headers, air intake, torque converter, gears).
#107
mine,
and 2 short clip
http://www.youtube.com/watch?v=XPGQN...e_gdata_player
http://www.youtube.com/watch?v=CCjlQ...e_gdata_player
and 2 short clip
#108
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Heres mine as it is right now
#111
Lots of cool swaps in here.Here are a few of my current setup.Ill post more after I swap to my lq4..just not sure what color scheme I want with the motor and painted red intake.
#115
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Engine: LS1/LQ4
Hawks 1-3/4" x 2.5". The crossmember fit where the factory one did, but I have a Hawks on it now. Stock driveshaft length until I put the 9" in.
#121
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
https://www.thirdgen.org/forums/ltx-...-z28-swap.html
#122
Car: 1983 Firebird SE
Engine: C5 LS1
haha old old post, but mine is still rocking. Did a head and cam swap and enjoying every minute of it. How is yours? Check out my swap thread;
https://www.thirdgen.org/forums/ltx-...u-gets-c5.html
Cheers-
#123
Engine: Cammed 6.0L LSX
I have about 6,000 miles on mine since 2009, no issues.
#125
Trans Adapt (4582) engine offset mount w/ the poly mount and Moroso Solid Motor Mount on the Spohn SBC K-Member.
#126
Stock LS3 oil pan, clears Spohn k-member and the steering doesn't hit it like it did with the gm f-body oil pan. I had to take the f-body pan back of tonight due to the steering not being able to be tightened down without binding on the oil pan. 8.8 qt. pan ftw...
#128
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Here are a few of mine. This is my second LS swapped Thirdgen. Both turbo cars.
This is my current 87 Z28. 5.3L, 4L80e, 9", turbo
