LT1 into 3rd Gen Camaro
Old Jan 23, 2009 | 10:36 PM
TremaineZ's Avatar
I've been reading up a lot on this swap. I wasn't going to do it until the summer, but my 305 blew so now I'm forced to do it. I have found the motor and pretty much all the gaskets, seals, accessories that are required to make the swap work. I'm having trouble finding a proper harness that I can use to get everything running properly.
I heard about the painless harness, but am having trouble locating what I need. I'm also interested in have a member with experience fabricate a proper harness, and paying him for his services. I read the threads on this subject but most are from 2001-2002 time frame. Any help would be great... thanks in advance
Old Jan 23, 2009 | 10:55 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: LT1 into 3rd Gen Camaro
Have you perused the engine swap forum? There's a specific subforum for LTx/LSx engine swaps.
Old Jan 23, 2009 | 11:34 PM
TremaineZ's Avatar
I was quickly browsing and totally skipped over it. I should look better next time before making the thread. Thanks dude for pointing that out.
Mods please close this thread
Old Jan 24, 2009 | 12:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moving it will suffice.
Old Jan 24, 2009 | 06:46 PM
TremaineZ's Avatar
Can anyone help me out with this?
Old Jan 24, 2009 | 07:40 PM
five7kid's Avatar
Look at the LT1 sticky in the top section of this forum. Then search for "lt1 wiring" and you'll get plenty of info.
You don't need a specific harness, although there are those that do them. Hawks, I believe, will convert yours, but it ain't cheap.
Old Jan 24, 2009 | 08:26 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
It's really not that hard these should help out and clear things up a bit
http://www.camaroz28.com/forums/showthread.php?t=474185
Here is the wires you will use off the LT1 harness.
http://shbox.com/1/harness_connector_faces.htm
Old Jan 25, 2009 | 01:21 AM
TremaineZ's Avatar
Thanks I'm gonna wire it myself if things are indeed that easy. Wish me luck.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
I'llrocya
Feb 2, 2016 11:43 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
