Wonder what was done to my LT1????
Old Feb 1, 2009 | 07:09 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Hey guy i bought a LT1 out of a 96 impala ss. It has a cold air intake that came with it that cost 350 bucks i looked it up! I start takeing some of the stuff off that i didnt need or want. Well what i found was new gaskets on the water pump then the timing cover? and also the oil pan? Do you think it was rebuilt? Cam swap mabey? Rebuilt? Give me ur guess!!!
thanks
kevin
Old Feb 1, 2009 | 07:12 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Wonder what was done to my LT1????
Well, considering these motors leaked oil like crazy, I would say it probably just had a new gasket set put on it.
Old Feb 1, 2009 | 07:59 PM
Ya mabey i just seen that the timming cover was taken off and was hopen for a cam swap lol.
kevin
Old Feb 1, 2009 | 08:44 PM
Mr.K's Avatar
Car: 1982' camaro Z/28
Engine: lt-1 out of a 95' impala ss
Transmission: viper spec t-56
Axle/Gears: Ford 9in 3.90 gears
i would guess that a cam would be a possibility youll just have to find out when you fire it up.
Old Feb 1, 2009 | 09:12 PM
Just wondering if it is a aftermarket cam and if i take the timing cover off will i be able to tell? Will it have a name on the end of the cam?
kevin
Old Feb 2, 2009 | 07:01 PM
Well took off the valve cover to see if their was something after market. It dosent look like it but new gaskets.
kevin
Attached Thumbnails Wonder what was done to my LT1????-mvc-001s.jpg   Wonder what was done to my LT1????-mvc-002s.jpg   Wonder what was done to my LT1????-mvc-003s.jpg
Old Feb 2, 2009 | 07:40 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
look all factory even the gaskets
Old Feb 3, 2009 | 12:43 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The most notorious leak on the LT1 engines was at the rear china wall of the intake manifold. Take off the intake and reseal it all around... new gaskets, and just use a HEAVY bead of silicone on the front and rear china walls. Don't use the rubber gaskets. The back of the intake is the most problematic leak spot. Other than that, its the generic SBC places... rear main seal, and valve cover gaskets.
Timing cover on the LT1 is a heavy cast aluminum peice, so it usually won't leak, but the crank and Opti seals on the timing cover can. You can still get those two seals from GM, which would be a wise thing to do. Don't get those seals anywhere else, they WILL leak if you use the aftermarket seals instead of the GM ones.... I spend 10 hours replacing them, only to have them leak just as bad with the new seals. Put GM ones in - still dry as a bone.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
