LQ4 engine
Old Feb 4, 2009 | 12:14 PM
kyle78's Avatar
LQ4 engine
I am new to chevy motors but I have picked up a camaro with a blown engine for cheep and am working on fixing it up. My question is i have got a 6.0 out of a 06 chevy van and was wondering if it was the same as what comes in the silverados and h2s. I was looking and it appears to be the same engine but it is only rated a 300 hp while the others are 325. What is the differance? I saw a article where someone took a lq4 and put l92 heads and a hot cam and bumped th hp up to something like 470 hp is this possible with the 06 van engine? I want to get good hp but need to know what I need to get it. Sorry for the newby questions but like stated before I am new to the chevy engines I am used to working on fords.
Old Feb 4, 2009 | 12:24 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: LQ4 engine
you might have better luck in the swap forums, you can get it in but it may cost a bit more $
good luck
Old Feb 4, 2009 | 12:43 PM
kyle78's Avatar
Re: LQ4 engine
I am not concerned with getting it in. My question is what is the differance between the 6.0 in the van and the 6.0 in the silverado and h2? There is a 25 hp differance and I would like to know why. Is it the sam engine just different intake or something else or is it a completely differnt model engine.
Old Feb 4, 2009 | 12:47 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: LQ4 engine
most likely its the cam and valvetrain. and/or the intake setup
motors are the same minus those two factors. If your gonna build it anyway it shouldnt matter
also take into consideration if its a roller cam or a flat tappet id say look up the motor specs on like google and compare the two
Old Feb 4, 2009 | 12:50 PM
kyle78's Avatar
Re: LQ4 engine
thanks I hoped that was the case. I will check to be sure though.
Old Feb 4, 2009 | 12:53 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: LQ4 engine
post the results up wed all be happy to help
Old Feb 4, 2009 | 01:47 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: LQ4 engine
LQ4 should have dished pistons and less compression than the LQ9
Old Feb 4, 2009 | 02:46 PM
kyle78's Avatar
Re: LQ4 engine
what is a good setup for the lq4? I would like to keep it fuel injected and would like to get around 450-500hp out of it with out nitrous or a blower. Any sugestions would be helpful.
Old Feb 4, 2009 | 03:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: LQ4 engine
www.ls1tech.com
poke around there for 2 days and read all the builds. depends on rear gear, converter, etc etc.
Old Feb 5, 2009 | 06:16 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: LQ4 engine
you can get 482fwhp with just a GMPP hot cam and carb intake with the year 2000 IRON heads. Mill some stock aluminum heads too bump comp to about 10.5 with a hot cam and you'd be looking at 500+ hp maybe more with some good porting.
L92 heads GMPP carb intake and a good cam will get you 550 fwhp. But like xpndbl said ls1tech is the place to be.
GENIII/IV engines are no joke.
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
