question about T56 fitment on LQ4 blocks
Old Feb 19, 2009 | 12:39 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Well more specifically, I need to know if an LT1 T56 will fit behind a '99 or '00 LQ4, which is the years the blocks had iron heads and longer crankshafts to accept the 4L80E. It is my understanding from another person's trial and error test that the T56 from an LS1 car will NOT bolt up to the back of an LQ4 from a '99 or '00 truck, but that a 700R4 and TH350 WILL bolt up, which leads me to believe that a T56 from an older car (LT1) would probably work? Can anyone help me figure this out?
Or here's another scenario: What if I put a crankshaft and flexplate from an LS1 block in the LQ4?
Old Feb 19, 2009 | 07:25 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: question about T56 fitment on LQ4 blocks
Good thinking on that, i havent read about that, but its likely.
Your correct that 99-00 LQ4's will not bolt up to a LS1 T56.
Curious as to whether a viper one might. They have a .5" longer input that needs to be turned to fit them into an f-body clutch/pilot.
Old Feb 19, 2009 | 08:02 AM
BlueZee28's Avatar
Well unless I find out for sure if there is a T56 out there that will work with this block, I'm getting my money back from the seller on Monday because he told me it was a 2001.
Old Feb 19, 2009 | 09:40 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Ill dig around LS1tech a bit, ive got a sneaking suspision, if a LT1 flywheel will bolt up, it should work. The difference between the LT1 and LS1 T56 is the LS1 has a longer imput shaft, i would think this would cure the issue
Old Feb 19, 2009 | 10:02 AM
BlueZee28's Avatar
I tried asking some people on LS1tech and haven't got a straight answer yet. I need to know by Monday because that's when I'm meeting the seller to get my money back
Old Feb 19, 2009 | 11:17 AM
BlueZee28's Avatar
I edited my original post with another question.
Old Feb 19, 2009 | 12:43 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
LS1 crank and flywheel would solve your problems.
Speaking of which, ive got one here.
hahaha, sheldon
Old Feb 19, 2009 | 02:03 PM
BlueZee28's Avatar
hahaha, sheldon
Sweeeet! I get to keep the block then you rock
Old Feb 19, 2009 | 02:10 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
hahaha, i try
Old Feb 19, 2009 | 02:59 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
so u have a 99-00 shortblock that u are trying to mate with lt1 t56, correct? usually lt t56 are assembled with ls parts to make work with ls.
and the lt bell houing will not allow the correct bolt pattern. the dowels on the ls block are correct for ls bellhousing. u can tell if u have a long flange, if the crank flange protrudes around .400 from the seal. if its standard flange, its dam near flush with the seal, maybe sticks just a tad.
jharrison5
Aug 19, 2015 05:53 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
BBSDesigns
Aug 11, 2015 07:39 PM
