swappin my 305 for 97 lt1
Old Feb 21, 2009 | 03:31 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
ok here i go next weekend i pick up an engine and tranny out of a 97 camaro for my 92 rs.. my current setup is a AT 305 tbi w/255k miles tranny shifts a lil hard and the engine is about 90% shot.. picked up the engine and tranny from the 97 for like 1k wiring harness ecu and all accessories included.. i have read and read and can honestly say i am car dumb.. i have a family frnd doing the mechanic work is there anything he might run into as a real problem swtiching all this for me.. any thing i might still need to get or should i be able to have this done for all i have between both engines etc? i have read forum after forum with pple arguing and saying the exact opposite of each other and not being mechanically sound it just leaves me lost... any thing i might need to know plse reply and tell me. oh wish me luck.. LoL
Old Feb 21, 2009 | 04:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
{Moved to the LTX and LSX swap subforum}
You might want to get the throttle cable out of the donor car if possible.
If you keep AC, the K-member will have to be notched in order for the compressor to clear. You can relocate the '92 compressor with special brackets, but it's a pain and tends to be expensive. Putting all the '92 accessories on the LT1 really isn't an option.
Finding a place to mount the PCM (powertrain control module - not called ECU or ECM starting with 4th gens) is a challenge.
This is all documented in the LT1 swap sticky in the top section of this forum.
Old Feb 21, 2009 | 07:37 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
Re: swappin my 305 for 97 lt1
talked to my uncle tonight who restores old chevy muscle mainly from the 60s era.. he recently put an lt1 engine from a 96 into a 68 rs for a guy just in the past month.. used the engine tranny outa the 96 only thing he had a problem with was fuel pressure had to get a fuel pump.. i think that is about the only thing i didn't buy off the guy.. ;-( so i will keep the thread active and informed as to what happens..
Old Feb 22, 2009 | 08:29 PM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
hey good luck with the swap! Are you doing anything to the motor while its out? and like those guys said you just check out through forum for other peoples swaps to get ideas of what you would want to do.
I used a 92 camaro throttle cable and it fits/works fine in my car. Since your car was EFI before this swap I don't see you needing to get anything for fuel pressure like i did ( my car was a carb before the swap) so I had to put an internal fuel pump and change out my sending unit. Really getting the engine in is fairly easy, hooking things up and finding spots to place stuff like your PS res. and PCM will be a little tricky... and the coolant hoses your going to need to connect to your third gen rad are 94 Camaro Upper hose, and 92 vette lower hose. The wiring was the only thing that really gave me trouble, its just a pain in the *** haha. But with the right help I'm sure you'll do fine! Good luck, any questions ask and I'll be happy to help you if I can.
Old Feb 22, 2009 | 09:23 PM
five7kid's Avatar
A stock TBI fuel pump won't properly feed an LT1.
Old Feb 28, 2009 | 02:02 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
ok picked up the engine and tranny today.. guy broke the air flow arm on it so i have to redo the intake is the KN intake worth the price or should i just go back to a stock assembly.. Also he kept alot of stuff that i thought we had agreed i got with the engine he kept starter ignition and pretty much all the accesories for his ws6 project he is working on.. including the high performance headers.. so suggestions on recomeneded parts and what won't go from my 305 to the new egine are greatly appreciated i am not a mechanic i pretty much buy and let other pple do the work so plse don't get too technical for me.. I have been argued with and people are trying to bully me into carbing the engine when we drop it in? is this even worth it? i have all the wiring and the comp box and such.. I got the engine mainly just the block and the AT tranny outa the trans am for a thousand bucks so i am well ahead of the game just not sure what more i will need.. got my fuel pump too.. i know i needed a new one of those.. anyway guys wish me luck we are gonna take detailed pics by step and catalog it cause this car will be a show car hopefully in 3yrs that is my goal from start to finish.. Wish me luck and detailed list and ideas are always a plus i love this gen car so much i love reading everything you guys have done and lookin at the pics even if i don't understand 90%.. i got enthusiasim though..
Old Mar 4, 2009 | 12:58 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
this is the current under hood setup for my rs lil mean 305 that is currently almost inoperable but for 255k miles it held out for along time..
Attached Thumbnails swappin my 305 for 97 lt1-100_1117.jpg   swappin my 305 for 97 lt1-100_1118.jpg   swappin my 305 for 97 lt1-100_1119.jpg
Old Mar 4, 2009 | 01:03 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
this is the new engine i have all of 500dollas in and my RS which i paid 1200 for so far i think i have one heck of a start.. i have looked and looked so far are hawks headers the only ones we can use for the swap that does not require some welding or cutting work? i don't have anyone that can do that for me at the moment is why i ask.. i have read thread after thread and it seems most pple either make thier own or use these.. at 800 dollas i will have more in them then the block.. we should be pullin the 305 this weekend and soon as i decide on what air intake set up thinkin K@N and what headers then the real work begins...
Attached Thumbnails swappin my 305 for 97 lt1-100_1120.jpg   swappin my 305 for 97 lt1-100_1121.jpg
Old Mar 4, 2009 | 04:16 PM
five7kid's Avatar
You can use any 3rd gen V8 headers that cover the ports. Being D-ports, 1-3/4" primaries do the job best. The bad news there is SLP no longer offers theirs. TGO member Dyno Don offers custom built 1-3/4" shorties w/y-pipe (PM him for details - he doesn't advertise). Hooker 2210's work, but they are long tubes and kill ground clearance.
I believe Hedman makes a D-port header, but not sure it's for 3rd gen chassis.
Or, get something like Hooker 2055HKRs, weld around the outside of the primary tube on the outside of the flange, and port match them to the heads.
Old Mar 4, 2009 | 07:04 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Most can get by with the 1 5/8 and you can get the matching y pipe with it.
https://www.thirdgen.org/forums/lt...hlight=headers (lt1 swap headers needed)
Old Mar 5, 2009 | 10:57 AM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
Link does not work.. page not found.. ;-(
Old Mar 5, 2009 | 05:15 PM
Car: 1992 camaro
Axle/Gears: 3:73
https://www.thirdgen.org/forums/ltx-...questions.html
If this dont work its in the sticky at the top.
Old Mar 6, 2009 | 05:46 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
ok so far i think this will be my monday order to summit's what you guys think? hedmans 68460 long tubes for headers.. KN intake 57-3010-1.. then after that and a few mnths when we are ready i am thinkin flowmaster duals 3 1/2in but i am not sure.. just wishfull thinkin..
Old Mar 7, 2009 | 06:16 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
setback.. sadly we were supposed to start today but i couldn't get my Rs to turn over the 305 has finally died we are afraid after changing battery plug wires and piddling with half a dozen other solutions we could think of we gave up.. just would not turn over no matter what we tried igniton and starter were trying but alas to no avail so next weekend trailering it to the garage to begin the long awaited overhaul and upgrade.. ;-(
Old Mar 13, 2009 | 02:06 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
What fuel pump did you end up getting?
Old Mar 13, 2009 | 06:07 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
he ended up givin me an in tank fuel pump new in box that he had for gm cars.. the numbers matched on the part to a 91-92 camaro and it says it is rated from 45-55psi so i beleive it should work...
Old Mar 16, 2009 | 06:45 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
the world conspires against me.. my shorty hedman headers got shipped to texas and my k@n intake to california.. LoL Summit appears to be sorry they are refunding my 30dolla shippin fee to instore credit towards my next order.. oh boy but another week in waiting to start.. sigh* If any of you recieved my stuff plse forward to florida for me you'll prolly be quicker..
Old Mar 16, 2009 | 06:52 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
Ended up gettin the hedmans shorties part 68479 since i am gonna run dual sraight pipes i am not worried about not having the long tubes with the sensors...
Old Mar 18, 2009 | 10:56 AM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
intake arrived today headers should tomorrow way to go to summit for fixing thier mistake..
Old Feb 23, 2011 | 01:12 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
after two years 3 mechanics and a few layoffs and medical issues settin me back in money i think my baby will be on the road in a few days.. we ended up carbing the enigine with an edlebrock 4 barrel and a few other things to make it a nice simple turnkey swap so that if i ever want to make it original again it will be easy to just drop another 305 back in it.. the engine is currently on a stand and ran about 430 hp this is the third guy that offered to buy it off me.. LoL we redid the cam and a few other small things to give it more power.. I truly can't wait to get my car back been way too long the new pics will be coming shortly.. I hOpe...
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
angel2794
Sep 8, 2015 06:22 PM
fbirdroller
Sep 2, 2015 10:27 PM
midge54
Aug 29, 2015 09:51 PM
