Milestone
Old Mar 14, 2009 | 08:45 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Milestone
BIG thanks to five7kid for coming over & helping me find that last 1/2" - which FINALLY allowed me to get the 2nd motor mount bolt through & fastened.
Old Mar 14, 2009 | 11:41 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: Milestone
What motor mounts are you using? Looks great so far
Old Mar 14, 2009 | 11:52 PM
V8Rumble's Avatar
Re: Milestone
Thanks. I'm using the Trans-Dapt adapter plates (that I bought from a certain moderator-type individual) w/ the stock motor mounts.
EDIT: Now comes the "INTERESTING" part of the swap - bolting on the front accessories while retaining the engine's variable-valve-timing functionality. I've always heard (over & over) that to do so, I'd need to retain the truck's serpentine accessory drive setup. Well, five7 & I brainstormed a little bit today, & we just MAY have figured out how to make it all "play nicely" together...
Old Mar 15, 2009 | 01:16 AM
Mike Massey's Avatar
Re: Milestone
great progress lokks great xcitedto see vvt swap in thirdgen badss
Old Mar 15, 2009 | 04:39 PM
Shift06's Avatar
Re: Milestone
You wouldnt happen to have a closer picture of those adapter plates would you V8Rumble? I am using similar units made by Sheldon, but I dont have "instructions" so I am not sure which way they are supposed to bolt up.
Old Mar 15, 2009 | 04:55 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Milestone
I sure hope you succeed. I'm a big fan of the VVT now that COMP CAMS has embraced it and offers us some cams for the LSes that use it.
Old Mar 15, 2009 | 08:28 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: Milestone
looking good!!
mitch, my best shot at some instructions is the longest side of the brackets goes up.
Would look like this |_/ best diagram
Old Mar 15, 2009 | 11:00 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Milestone
:drool: l92 :drool:
Old Mar 16, 2009 | 01:25 AM
V8Rumble's Avatar
Re: Milestone
Well, I went out there & took a few pics in an attempt to show how they're mounted, but the clamshells do a terrific job of hiding the plates, so that didn't work so well.
The best way that I can think to describe it is that the longest side is at the top (as Sheldon said), & the side that's cut diagonally goes to the front of the car. I hope that's enough to be helpful...
Originally Posted by mw66nova
:drool: l92 :drool:
Man, I honestly really needed that tonight, thanks. BTW, I finally got to watch your startup vid tonight - that's a really nice looking car you've got there!
Old Mar 16, 2009 | 08:10 AM
mw66nova's Avatar
Engine: 7.0L
Re: Milestone
that's what i'm here for! lol...thanks for the compliments on the car...the vid hides alot, lol....it needs a bath BADLY, but i'm afraid to get into that while i'm still working out bugs...
Old Mar 16, 2009 | 10:06 AM
Shift06's Avatar
Re: Milestone
No that should be fine, I am pretty sure I know what you guys mean.
Old Mar 18, 2009 | 06:44 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: Milestone
Clean! *drools*
blkws6frbrd
Dec 4, 2014 10:11 PM
