6.0 intake questions
Old Mar 18, 2009 | 03:52 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
anyone have any comparison of an otherwise stock lq4 with the ls1 or ls6 intake. i am planning out my swap, and i want to know if the ls6 will actually gain enough on this engine to be worth approximately double the price. any input? thanks in advance guys,
nick
Old Mar 18, 2009 | 05:51 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: 6.0 intake questions
From another thread here
Ken Duttweiler tested intakes on a Modified LQ9. Going from the truck intake to the LS6 piece gained 10 horses. From LS6 to LS2 lost 10 horses. From LS2 to FAST gained 20 horses. $900 for the FAST versus $300 for the LS6. I'm not paying $600 for only 10 horses.
Now the other question is, do you also want to spend money on a cowl hood so it will clear? It will need to be at least a 4" cowl.
Old Mar 18, 2009 | 06:09 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
For the truck intake?? No, until recently I had a truck intake manifold, & there's NO WAY that it's that tall. You'd need a scoop or an aftermarket hood, sure, but a RA-I or RA-II should clear it...
Old Mar 18, 2009 | 06:41 PM
Klortho's Avatar
Car: 1987 GTA
that's what someone had posted up in another thread they had to go with to clear it *shrug*
Old Mar 18, 2009 | 06:53 PM
V8Rumble's Avatar
Ah, gotcha. Yeah, I'm fairly sure that a simple 2" or 2.5" cowl would clear it...
Old Mar 18, 2009 | 07:17 PM
Klortho's Avatar
Car: 1987 GTA
I remember someone posting pictures up and it looked like it stuck really high in the front but dunno, I know the LS6 intake is better for the HP
Old Mar 19, 2009 | 01:10 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
ls6 flows better and will make more power.
there is a tuck manifold that flows just as well as a ls6, but uses 90mm tb
Old Mar 19, 2009 | 01:42 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
i know the ls6 flows better than the ls1, but i want to know how much actual performance it would gain over the ls1 intake. i'm putting a car intake on a lq4, i'm just trying to decide if i want the ls1 or ls6. will i feel much difference for the extra $150? if they're the same in low end, just 5-10 more horses up top with the ls6, then i'd be cool with the ls1 and save some cash. if the ls6 gives me 15 ft-lbs, then i want it for sure.
Old Mar 19, 2009 | 01:50 PM
Car: 02 SS
a c5 ls1 flows a tad better than the fbody ls1, it will be enuff for a stock or bolt ons lq4, u wont really need a ls6 unles u plan on aggressive cam, etc. a ls1 intake will be plenty for up to 450bhp. i ran my camaro for yrs. with a stock fbody intake making 385rwhp with just bolt ons and a tune.
the c5 ls1 intake does flow somewhat better than fbody, and looks just like a ls6. and ther pretty cheep too.
Old Mar 19, 2009 | 02:28 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
sweet, thats what i needed to know. thanks.
Old Mar 19, 2009 | 05:45 PM
HDon22s's Avatar
Car: 88 iroc
Engine: lq4
Transmission: 700r4 till it dies.
If you are using the truck acc. I think this biggest problem is the alt. being up top not so much the intake itself. The position of the alt. can be changed easily though. A 4" cowl is needed for a carb setup.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
