How did you connect your speedo cable??
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
It just came to me that I never hooked up my speedometer cable, because I forgot haha... But I remember looking into a conversion box to go from my cable speedo to my T-56 connection from Xcat i believe it was called? I'm curious how accurate this speed transfer box is, and is there any other way to get your stock speed cable to the T-56 without spending $300 which is what that xcat cable box costs i think. Also did GM ever make a digital gauge cluster that may have a connection that would just plug into the transmission instead of the box? Well any help with my question would be great. Thanks guys!
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: How did you connect your speedo cable??
Mine had an electric speedo, they didn't come in the Camaro's until either '90 or '91.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Not just the cluster, there's more behind the cluster that has to be changed. I have the entire dash from my '91 RS LO3. Lots of things different from my '88 Camaro LO3 dash.
Car: 1987 GTA
He would need the cluster, and all the dash wiring. I'm not for sure if he would need the entire dash or not though.
Engine: 357 LTx
Oh great this is getting more complicated than i was hoping haha. So IF i upgraded to the 90-92 gauge cluster I would have the electronic speedometer cable that would plug into my 6spd T-56 transmission, But I would have to rewire all the guages..correct? rewiring meaning simply splice in wires to their correct counterparts? or is is more involved?? And has anyone got this xcat box I mentioned before? is it a waste of money ?? Thanks for the help!
wigmobile
Feb 26, 2025 02:56 PM
topteam54
Oct 6, 2015 12:21 AM
gta892000
Sep 16, 2015 12:37 AM
1986, 700r, 84, cable, camaro, connect, connection, gen, locationn, plug, reconnect, speedo, speedometer, tranny, transmission
