Updates to the camaro
Old Mar 9, 2009 | 03:54 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Got my battery in the back, Interior almost complete, Air intake almost complete(waiting for two more silicon sleeves, and computer moved to under the fuse box.
Old Mar 9, 2009 | 03:55 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: Updates to the camaro
Old Mar 9, 2009 | 03:56 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Old Mar 9, 2009 | 06:25 PM
99b4c's Avatar
Car: 99 B4C, 89 RS
Engine: LS1, 2.8
Transmission: 4L60E, T5
Axle/Gears: 3.23, 3.42
Awesome build and update, I like to see the 5.3 swaps. Are you running the truck intake? I plan to do a 5.3/T56 swap in my 89 RS and would like to keep the stock hood. Is your speedo electronic for the 4l60e?
Old Mar 9, 2009 | 07:22 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Spend the 30$ for new hood struts
Pet peeve
Old Mar 9, 2009 | 07:34 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Pet peeve
he's running a fiberglass hood, new hood struts are too strong for some company's 'glass hoods, and the hood struts for the factory 'glass hoods are twice the price and special order(as in, sometimes they're not available)...dueche
i could see him using the $60 towards more go-fast goodies
the build looks really good, but i'm curious why you've gone with the colder TR6 plug versus the TR55 which is what most folks run...unless you got a little spray you're not letting anyone know about
Old Mar 9, 2009 | 11:44 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
didnt know that, thought fiberglass was as strong :/
Old Mar 10, 2009 | 12:14 AM
mw66nova's Avatar
Engine: 7.0L
it depends on the brand. some of the cheaper ones are thinner than the more quality ones and will crack around the hood hinges with the added stress. the best bet is to find some that aren't completely blown that will no longer hold up a steel hood, but still strong enough to hold up the 'glass hood.
...and it kinda sucks that you picked out the things wrong with the car after he put in one of the most sophisticated pushrod v8's on the road today and it's running well and posted pics of the updates...
Old Mar 10, 2009 | 01:56 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Yes that is the truck intake under a 4" cowl. I have all electric gauges. I hadn't got my speedo working yet still trying to figure that one out.. If I connect it straight to the vss sensor then the tranny won't shift and if I use the output from the computer It says I'm going a max of 5 mph.
Old Mar 10, 2009 | 02:04 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Never knew about the worn out hood struts idea. May need to find some. Good looking out on that. Also didn't think about the 55 plug. My buddy recommended the TR6. Would that explain why it dies when I crank it until I get it going? almost like I have to let the pcm relearn an idle.. Also it will sometimes die when I stop at a stop sign or something similar.. Any help is appreciated.
Old Mar 10, 2009 | 06:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've got 3 pairs hanging in the garage in case I go fiberglass some day. New ones seem to last about 3 years.
Old Mar 10, 2009 | 07:54 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
you mind sending me a pair. lol
Old Mar 10, 2009 | 09:06 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
They're generally pretty easy to find in the junkyard...
Old Mar 20, 2009 | 11:32 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
Finished up my intake!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Fast355
Dec 2, 2016 06:33 PM
jackhammer
Aug 15, 2015 10:04 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bryan623
Aug 10, 2015 11:33 AM
