4th gen fuel tanks
On Probation
Engine: several
Transmission: none
Axle/Gears: none
4th gen fuel tanks
I found a source that has a few different ones to choose from, for $65-$75, so, does it matter which year or engine the tank comes from for our LSx swaps?
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: 4th gen fuel tanks
My opinion...go with the later plastic tanks. I think there was a difference from 98 to 99-02...but I cant remember.
The plastic tank will bolt right in after you modify the fuel filler neck. Which is really easy because its just a piece of rubber hose between the tank and the spout. Just do some searching on here for 4th gen fuel tank....plenty of info. Also in the sticky.
J.
J.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
they have a half dozen of the plastic ones, so if anyone needs one, PM me.
Car: 1992 GTA
Axle/Gears: 4.10
J.
J.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I appreciate the info, thanks. Who wouldn't want an extra 1.3 gallon capacity? Even if it makes the tank more difficult to fit.
Car: RS
Axle/Gears: 9" for the ladies
98 is metal as stated.
Someone before said some of the attached emission stuff on the top of the tank differ's from v6 to v8 if your one of those people.
Transmission: 4L80E/4L80E
Correct. Not all plastic is created equal.
The V8 tanks/pumps have the regulator built in, the V6 tanks do not. That isn't too big of a deal, because you can always use a Vette fuel filter with the V6 tank/pump.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
we are saved! Every one of those tanks I found is from a 3800 car. Now I just hafta sell my PlayStation2 for enough to cover the $75 plus tax.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
