Possible vortec swap
Old Mar 23, 2009 | 11:05 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
So I was recently at the junk yard looking around for parts that could be of some use. Then i discovered a fresh vortec motor that was still sitting in a silverado. Guy that owns the junk yard says its the 5.3 L engine and that it still cranked over and turned on. Badass I thought. So to my suprise he said if i pulled the engine myself i could have it for $200. So would this engine be worth a rebuild of trying to reach my goal of 450 hp.? Also what would have to be changed to make this engine fit right
Old Mar 24, 2009 | 07:56 AM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
Re: Possible vortec swap
What year is the truck? Very possible its of the LS series of engines... so yea, probably just cam and tuning will put you close to where you wanna be.
Pretty sure you'd have to swap out the intake and oil pan for F-Body parts though.
Old Mar 24, 2009 | 09:17 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
take everything! the intakes are different than ours so you will need that, as well as the exhaust. and take every wire that goes from the computer to the engine, and take the computer too. the entire box.
DONT CUT ANY WIRES. you will probably need to go into the right fender well area to pull the wires through CAREFULLY.
it will probably have a vats - does the key have a resistor in it? if it does take the key and the vats unit which should be under the dash, drivers extreme left side near the fuse block. the computer is programed to look for it. but then it only want to see a yes its the right key response before it allows the engine to start.
so you either get a new chip and remove the look for vats command, or you keep the chip and make sure the vats you have in your car and key match.
Old Mar 24, 2009 | 10:57 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It would be illegal to put a truck engine in a car.
Old Mar 24, 2009 | 11:05 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The legality issue is easy. The 5.3 block can be bored to 5.7L. New pistons and rings, rebalance the crank. cam: getting a good used Camaro one is easy and cheap. heads: just hafta have a machine cut them for the 2" intake valves. computer: not hard to get the truck computer reflashed with a stock LS1 Camaro tune. This is the route I'm taking. An iron-block LS1.
Old Mar 24, 2009 | 11:06 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If the truck has a working automatic trans and is not 4 wheel drive, take that, too.
Old Mar 24, 2009 | 11:14 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, this is an LSx swap. So, moving this to that subforum.
Old Mar 24, 2009 | 11:49 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I know that's true in Kalifornia but I seriously doubt that it is in Texas (where the OP is). It would be a very good idea for him to confirm that there aren't any local regs to be aware of though...
BZZZT. "Thank you for playing, please enjoy our lovely parting gifts..." In the GPRK (Glorious People's Republic of Kali), they check the casting number of the block against their list/DB, so the bore size is totally irrelevant. If the casting number says that it was made for (or originally in) a truck, then the swap is illegal - end of story.
EDIT: Note to the OP - $200??!?!? I'd jump on that like a pit-bull on a T-bone!!
Old Mar 24, 2009 | 02:02 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
awesome. What size of cam would go great with this engine? I just got home right now with the whole computer harness and tranny pulled in the garage. Engine should make it here tomorrow. Would making the swap be a pain in the rear and also i'm not too great with the whole computer wiring. From the looks of it, it could give some pretty bad head aches. It's the first time i've actually messed with this kinda stuff. so excuse the knowledge that i dont have yet.
Old Mar 28, 2009 | 07:13 PM
five7kid's Avatar
If you get a factory harness, you don't really have to do any "computer wiring". Just electrical wiring.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
earlpote
Aug 28, 2015 10:42 AM
jharrison5
Aug 19, 2015 05:53 PM
