LT1 swap ?s into 88 irock 350 tpi
Old Mar 28, 2009 | 11:33 AM
oldrtyblg23's Avatar
what would be easier and/or better an f body LT1 or a Y body corvette LT1 i have the 700r4 and unless i find a deal on a combo LT1/4L60E or 6speed im gonna stick with my 700r4 i need some help and suggestions 2 make my swap happen
Old Mar 28, 2009 | 06:17 PM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
Re: LT1 swap ?s into 88 irock 350 tpi
really the only few differences between the vette LT1 and the Fbody LT1 is the acc. bracket, a possibly an oil cooler line (which I heard are garbage anywase) So it just depends on where you would like your alternate mounted and the belt routing. If you wanna run the stock AC on your IROC i would go with the vette LT1, if your not worried about having AC its just a personal preference choice on where you want your acc. mounted & if you want an oil cooler.
Old Mar 28, 2009 | 09:30 PM
thanks alot man i dont think im going with the a/c but i like the vette setup a lil more
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
