Got a Cam!?
Old Apr 6, 2009 | 04:54 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Got a Cam!?
Hey guys i am going to get the money order tommaro what do you guys think? He said " 230/236 HR113, Lift is 0.544/0.554 with 1.6 rockers. Its inbetween the CC305 and the CC306." He said that it was run for about 15k miles? And he ran it in a stock corvette he ran 108mph when stock is 101mph?
Then what do you think i will run with this cam?
96 impala ss (iron heads)
complete rebuild 10:5 compression
3:73 posi
that cam w/ 1.6rr
high performance shift kit
3000 stall
http://i229.photobucket.com/albums/e...e/Cam230_1.jpg
http://i229.photobucket.com/albums/e...e/Cam230_2.jpg
http://i229.photobucket.com/albums/e...e/Cam230_3.jpg
http://i229.photobucket.com/albums/e...e/Cam230_4.jpg
http://i229.photobucket.com/albums/e...e/Cam230_5.jpg
thanks
kevin
Old Apr 11, 2009 | 10:22 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Got a Cam!?
You probably already bought it by now, but it's a bit large. Not that it won't help, it will give you top-end power, but it's a bit large for your stock LT1 iron heads. That cam with 1.5:1 rockers will pull to 6500 rpm with good heads like AFR 180cc LT1 heads, but your heads are really a restriction above about 5600 rpm. That cam will also need some tuning, and you'll like it more with about a 3000-stall converter if you have an automatic. A better cam for your heads would be the GM "H.O.T." cam. 218/228, 112, 525/525 w/ 1.6:1. It'd like a 2400 stall.
Old Apr 11, 2009 | 05:50 PM
Re: Got a Cam!?
No i went with a diffenet cam. its a Lloyde Elliot cam.
Specs:
223/230 .540/.540 Lift 111 LSA
Mild to choppy idle. Good HP/TQ through out and a very usable power band
1900-6200 RPM
kevin
Old Apr 11, 2009 | 09:32 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Got a Cam!?
Specs:
1900-6200 RPM
kevin
Thats a pretty good choice for a stock-ish LT1. I would probably go with something similar if I do a cam in my '97 some day. Will still need tuning and probably more converter if its an auto, but a pretty good street/strip cam. Will sound really nice too.
Old Apr 12, 2009 | 04:57 AM
Re: Got a Cam!?
Ya im hoping it will make at least 300rwhp!? Then i will be going with a 3000 stall.
kevin
Old Apr 12, 2009 | 09:07 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Re: Got a Cam!?
That cam has some folks in the 380 rwhp range with mild heads, you should see 300.
Old Apr 12, 2009 | 09:41 AM
Re: Got a Cam!?
Ya i have the iron heads right now. Later on down the road ill put some good heads on but i think 300rwhp will be able to beat alot of cars on the road.
kevin
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
